What Causes Objects to Become Charged?
  • Thread starter Thread starter kripkrip420
    Charge
Objects become charged due to the loss or gain of electrons, which alters their balance of positive and negative charges. In solids, this can happen through processes like friction, where electrons are transferred between materials, resulting in one object becoming positively charged and the other negatively charged. While ions are typically associated with liquids and gases, solid objects can also exhibit charge due to the movement and alignment of their electrons. The proportionality constant in Coulomb's Law is derived from experimental measurements made by Charles Augustin de Coulomb. Understanding these principles helps clarify how both ions and solid objects can carry electrical charges.
kripkrip420
The problem is that I don't understand what causes an object to become positively or negatively charged. I know that, in chemistry, ions represent charges in voltaic cells. For example, cations become reduced and their electrons travel to the anode. This creates a negative charge at the anode because electrons from the solution containing the cations travel to that location. The opposite happens with the anions. They gain the electrons and become negatively charged. But this is all for solutions and ions. What happens to a solid object, like glass, when part of it becomes negatively or positively charged? Do ions exist on the surface when the charge changes? Also, where did the proportionality constant for Coulomb's Law come from? Thank you for your help!
[Explained above]
I'm not sure what you're asking. I guess one way to talk about charge is that it's a fundamental property of particles that creates an electromagnetic force.
What is an ion?
Why does an ion have electrical charge?
The proportionality constant comes from careful measurement. Charles Augustin de Coulomb was one of the first to make such a measurement.
SammyS said:
What is an ion?
Are you asking me?
Ions have electric charge because they have lost or gained electrons with respect to the original atom. Charge represents how positive or negative an ion is relative to its' neutral atomic state. This, however, does not explain why an object that is solid can have such properties. Ions can exist only, as far as I know, in a liquid or gaseous (plasma) state.
kripkrip420 said:
Are you asking me?
Ions have electric charge because they have lost or gained electrons with respect to the original atom. Charge represents how positive or negative an ion is relative to its' neutral atomic state. This, however, does not explain why an object that is solid can have such properties. Ions can exist only, as far as I know, in a aqueous or gaseous (plasma) state.
FTFY
What you seem to be asking here is how a solid can carry an electric/magnetic charge. At least I think so. What you have to consider is not just the amount of positive and negative charges in the solid, but also their alignment.
kripkrip420 said:
Are you asking me?
OK, a solid object may also gain a some electrons or lose a some electrons --- relative to the object being neutral.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
