What does atmospheric pressure have to do with the gauge pressure?
Gauge pressure is the pressure relative to atmospheric pressure, and it is crucial for understanding how pressure gauges function. Atmospheric pressure acts on both ends of a tube, but without internal pressure greater than atmospheric pressure, there is no movement. The discussion highlights that gauge devices typically include a spring that balances the forces from tire pressure and atmospheric pressure. Without the spring, the gauge would not accurately reflect the tire pressure. The explanation in the referenced video may have oversimplified the role of atmospheric pressure in this context.
Callmelucky
Please explain if you want/can, thank you.
P = F/A
P(total) = P(gauge) + P(atm)
In this video( ) it's explained what is gauge pressure.
Can someone please explain to me what does atmospheric pressure acting on a tube(in video at 3:51) has to do with displacement of a tube?
I understand that the atmospheric pressure acts on the tube, but in the open space that does not cause the tube to move, it just causes pressure on both ends of the tube, therefor no movement.
So if there was no pressure inside the tire that was greater than atmospheric pressure the tube wouldn't move.
I can understand that gauge devices work if they have some kind of spring inside them that takes of atmospheric pressure from total pressure which is 1.033 kg/cm2 at the sea level. But I don't understand how atmospheric pressure does that by himself(as he said in 3:51 "the atmospheric pressure pushes back on the tube")
Thank you.
My advice is to never watch this video again.
  • Love
Likes Tom.G and Callmelucky
Callmelucky said:
Homework Statement:: Please explain if you want/can, thank you.
Relevant Equations:: P = F/A
Well I guess he over simplified in his quest to explain gauge pressure.
and your right there would be a spring within the guage
Your ordinary pencil tire gauge looks like this inside.
On one side of the orange piston there is the force from the tire pressure.
On the other side is the force from the compressed spring AND the force from the atmospheric pressure.
If there was no spring the piston would more completely to the right end regardless of tire pressure.
Likes Callmelucky and Lnewqban
Thank you.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
