What Happens to Blue Sphere Silica Gel at High Temperatures?
When blue sphere silica gel is exposed to high temperatures exceeding its thermal stability for several minutes, it undergoes both chemical and physical transformations. At elevated temperatures, the silica gel can lose its moisture-absorbing properties and may transition into a less effective form. This transformation can lead to the formation of compounds that may not efficiently absorb and store moisture. If the silica gel breaks after being subjected to high heat, it can potentially leak moisture, although the specifics of this behavior depend on the extent of the thermal exposure and the resulting changes in its structure. The discussion highlights concerns about the maximum temperatures encountered in environments like microwave ovens and their effects on the silica gel's functionality.
carlos78
What type of chemical and physical transformation occurs in the blue sphere silica gel when it is subjected to very high temperatures above the temperature supported by it for several minutes?
does it turn into a compound that will absorb and store moisture and water inside and can leak if it breaks? ex. maximum temperature of a microwave oven in 10 and 15 minutes
Chemistry news on Phys.org
my doubt is another what happens to it at high temperatures it turns into something that absorbs and releases liquid
(Mentor Note -- The OP was found to be a sockpuppet of a problematic user who was banned in the recent past, so this version of that user is now gone as well, and the thread will be closed now.)
Likes dlgoff and topsquark
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
