hadi amiri 4
- 98
- 1
can anyone tell me that what is i(\sqrt{-1})
hadi amiri 4 said:I can not understand the existence of this
hadi amiri 4 said:pre unive math
hadi amiri 4 said:can anyone tell me that what is i(\sqrt{-1})
Astronuc said:i is defined by i2 = -1.
tiny-tim said:Hi hadi amiri 4!
nicksauce is right … i is defined as a square-root of -1.
Mathematicians can define anything they like.
i does not exist.
Or, rather, it only exists in mathematicians' imaginations.
Why does its existence worry you?![]()
Nice! But I suspect a student's ability to appreciate this will depend strongly on whether or not they have been taught mathematics axiomatically.arildno said:Well, then you know about 2-D coordinates, don't you?
Instead of considering the quantities that lie on the real number line (i.e, the so-called "real" numbers!), let our basic "quantities" be points in the PLANE in stead.
We will call these quantities "complex numbers".
Thus, that i*i=-1 is something we are able to construct as long as we regard our NUMBERS as points in the plane, and in addition, have defined our "multiplication" in a smart manner as above.
Oh, tiny-tim, what were you thinking? "i" only exists in mathematician's imaginations in exactly the same way other abstract things, like the numbers "e", or "1/2", or "1" do. I understand that but the person who wrote the original post is certain to misunderstand it.tiny-tim said:Hi hadi amiri 4!
i does not exist.
I hadn't thought of that, both +i and -i are solutions, but how can you say that one is the positive root and the other is the negative root? Hmmm, very interesting comment. I guess that is the ultimate source of conjugate symmetry.Redbelly98 said:It occurred to me some time ago that this definition is ambiguous, since there are two solutions to that equation.
While this ambiguity does not seem to matter in practice, I'm still surprised that it never seems to get discussed.
Gokul43201 said:Nice! But I suspect a student's ability to appreciate this will depend strongly on whether or not they have been taught mathematics axiomatically.
Werg22 said:i exists just as much as the number 1. i is simply the element (0, 1) of the field formed by R^2 over addition and multiplication of complex numbers.
HallsofIvy said:"i" only exists in mathematician's imaginations in exactly the same way other abstract things, like the numbers "e", or "1/2", or "1" do. I understand that but the person who wrote the original post is certain to misunderstand it.
Oh, and as I am sure you have seen from my previous posts
I object to the bald statement "i is defined as a square root of -1". You did put "a" which a good thing but a definition has to specify it exactly. That does not say which of the two square roots of -1 is i.
tiny-tim said:Sorry, but I think numbers like 1 2 3 … existed even in cavemen's imaginations.
matt grime said:My standard line is: the second I stub my toe on a '1', I'll believe it exists in a meaningful sense. The counter point is: when you stick your hand in the electric socket, it isn't the imaginary part of the current that kills you.
we know that
\sqrt{a}\sqrt{b}=\sqrt{ab}
so
\sqrt{-1}\sqrt{-1}=\sqrt{-1*-1}=\sqrt{1}
=1
and i^2=-1
finally 1=-1
hadi amiri 4 said:we know that
so
=1
and i^2=-1
finally 1=-1
You assume that cavement couldn't be mathematiciains? Do you write Geico commercials?tiny-tim said:Hi Werg22!
hmm … this is obviously a usage of the word "simply" that I haven't come across before …
Hi HallsofIvy!
1/2 of an apple is an object. 1/2 of a loaf of bread is an object. "1/2" is none of those things.And when it came to dividing food, so did numbers like 1/2.
No, it is not. In fact, that is not a definition at all because, again, in the real number system there is no such thing while in the complex number system there are two and that definition doesn't tell us which of the two is i.e = 2.71828182889045etc is of course a much more recent invention of mathematicians … but is it an invention?
If you defined it (using that decimal series) it to a layman, surely the layman would reply "You haven't defined anything new … you've only given a name to something which I see no use for! I wish you well with it! But it was already there before you gave it that name … you didn't define it, you only named it!"
But i wasn't there before …
if so, where was it?
In that sense, hadi amiri 4 is quite right to question its existence!
erm … sorry … what posts?
"i" can be defined in many ways.
Here's one definition: add a symbol "i" to the field R, define ii = -1, and then enlarge to a field.
Obviously, there are no other elements of the new field whose square is -1, except for -i.
What's wrong with that?
All other definitions (the Argand plane construction, the pairs construction, etc) are just models of this definition.
And this definition … of i as a thing whose square is -1 … is the most basic.![]()
It is useful in electrical engineering and signal processing and anytime you are doing a Fourier transform. Perhaps there are other applications also, but that is the field that I use it in. In the Fourier transform and signal processing complex numbers are used to represent phase information and i is a phase shift of 90º wrt 1 (i.e. a sin rather than a cos).Gear300 said:Wait...to sidetrack just a little...what are the physical meanings i can hold (is it only applicable as a mathematical concept)?
Careful now! Strictly speaking you have just said that e= \pi!kts123 said:i is a mathematical entity equatable to pi.
Yes, and, I would argue (and have here), in the same sense that any number exists!i exists in the sense that pi exists -- that is, under special situations, it is a value that arrises naturally.
A cartesian coordinate system does not "exist," but it most certainly behaves as if it does when we use trignometry to measure apparent size, paralax, or a number of other things (and in these contexts, pi also appears.)
i is easily demonstrated to exist in the same sense as pi via observing the "addition" of forces. Pi let's us represent angle, for example Pi/4 rads over "level" yields maximum distance when firing a cannon, and complex values allow us to "add" forces (as well as other useful applications.) Anyone claiming that i does not "exist" must also concede that pi does not "exist." (In fact, after studying complex analysis, I would have to say that complex numbers are the "true" numbers, making coherence of ambigous concepts such as "limits at infinity," "rotation," and other topologies.)
I'm not an expert though, and I have no room to mention topology considering I have almost no experience in the field. Still, I feel that complex numbers are extremely real -- perhaps more so than even integers (well, that's going a bit far, but still.)
God knows, I have discussed it on this forum often enough to sound as if I had a mania on the subject!Redbelly98 said:It occurred to me some time ago that this definition is ambiguous, since there are two solutions to that equation.
HallsofIvy said:… In fact, that is not a definition at all because, again, in the real number system there is no such thing while in the complex number system there are two and that definition doesn't tell us which of the two is i.
Careful now! Strictly speaking you have just said that !
HallsofIvy said:God knows, I have discussed it on this forum often enough to sound as if I had a mania on the subject!
DaleSpam said:It is useful in electrical engineering and signal processing and anytime you are doing a Fourier transform. Perhaps there are other applications also, but that is the field that I use it in. In the Fourier transform and signal processing complex numbers are used to represent phase information and i is a phase shift of 90º wrt 1 (i.e. a sin rather than a cos).
<br /> <br /> Halls, Do you have a sign error in that 2nd expression?HallsofIvy said:In the general theory of relativity the "metric" can be written as
ds^2= dt^2- dx^2- dy^2- dz^2[/itex] <br /> or as<br /> ds^2= -(dx^2+ dy^2+ dz^2+ d\tau^2)[/itex]<br /> <br /> where \tau= it<br /> <br /> The latter form makes it more like the &quot;Euclidean&quot; metric.
hadi amiri 4 said:what is the meaning i^i?
Gear300 said:has it ever occurred in any physical theory that i played a role in the meaning of the theory? If not, then much like other concepts, its meaning would occur more or less mathematically, right?
Redbelly98 said:i appears explicitly in the Schrodinger Equation (time-dependent version).
<br /> i \hbar \frac{\partial \psi}{\partial t} = H \psi<br />
I'd have to think hard to put into words just how i "plays a role in the meaning" of quantum mechanics. But this is arguably the single most important equation in 20th-century physics, and it contains i.
hadi amiri 4 said:What is the meaning Sin(i) do we have imaginary angel?
HallsofIvy said:sin(i)= (e^{i^2}- e^{-i^2})/2i= (e^{-1}- e^{1})/2i
Complex numbers are built into quantum mechanics at every level. Particles are represented by complex-valued functions e.g.Redbelly98 said:i appears explicitly in the Schrodinger Equation (time-dependent version).
