- #36
Lapin Dormant
- 132
Yeah, but it wouldn't provide any propulsion then. Also, there's no such thing as a silencer, just suppressors. Keep in mind that an effective one for a .45 auto pistol is from 2 - 4 inches in diameter and 10 -14 inches long. One for a high-power rifle is much larger. The whole point of the thing is to capture all of the expanded propellant gas and then release it slowly. You need enough internal volume, plus baffles, reversal plates, etc. to accomplish that. Think of how much gas is coming out of a turbojet.Ki Man said:wouldn't a modified and enlarged version of a rifle's silencer help decrease the noise level made by a jet just a little at least
Ki Man said:see with jet powered cars and stuff for everyday use, there comes a bunch of problems
problem: birds and small animals like nearby cats getting sucked into engine (this problem is solved a lot in the commercial airliners and stuff with small birds, but we've never had to deal with scruffy climbing up on your back while you put on your jetpack)
problem: humans getting sucked into engine (whoa! i knew i shouldn't have worn this baggy jacket. oh well. i'll just sit and wait for the paramedics)
problem: noise level of having a jet engine in a neighborhood (keep it down over there! don't make us shoot you out of the sky)
That's true and not so true. Many turbines today are operating with thousands of hours between overhauls. The issues would then become would the average person really be willing to be more vigilant with their day to day responsibilities in general maintenance and when the repairs/overhauls do happen, they would be more extensive than, say, a v-6 would. That being said, the major gripe most people have today is that many feel engines are too complicated now and that they can't be worked on by the lay person. So I think there's a bit of a tradeoff there. However, the cost factor is what is going to be the killer. Until production numbers get very large, indeed the cost will be pretty high.sid_galt said:Even if you solve all the above problems, you are never going to see widespread use of jet engines in cars. They are too expensive and require much more maintainence than ordinary engines.
Not really. Turbines are usually pretty sensitive to back pressure. We do tests where we intentionally do that and the increase in back pressure has the most notable side effect of an increase in turbine temps which now throws your cycle off and puts more stress on the turbines. The most notable method of silencing today is the mixing assemblies at the rear of the engine. The idea is that mixing the colder bypass flow with the exhausted core flow does help to decrease the noise.Ki Man said:wouldn't a modified and enlarged version of a rifle's silencer help decrease the noise level made by a jet just a little at least
Not so practical. The noise being emitted is a broadband frequncy, it's not a nice, simple single frequency. That means whatever is doing it has to have the computing power, plus the output power to be able to mimic what is coming out in real time.Lapin Dormant said:If you would want to silence it, use a Counteracting sound wave as to annul the emiting wave.
Means use a microphone and computer to pick up on the sound emitted, generate a Counterwave to it, broadcast it back at the originating sound wave, the Two cancel each other, and the noise, disappears.
Practical solution.
Yes, and the time differntials must be met between pickup, re-creation as inversion, re-emission towards the target.FredGarvin said:Not so practical. The noise being emitted is a broadband frequncy, it's not a nice, simple single frequency. That means whatever is doing it has to have the computing power, plus the output power to be able to mimic what is coming out in real time.
I've never seen a frequency analysis of a jack hammer/compressor set, but I doubt it very much. Also, they don't have nearly the volume of a decent sized jet. (Note that in the case of a turbine-driven ground vehicle, it's mechanical power from a PTO that drives the wheels. Lots of ducting and expansion chambers and whatnot can be incorporated in the exhaust path because the thing doesn't rely on thrust. That's why the experimental gas turbine buses in Germany and similar are alright for street use.)Lapin Dormant said:is that broad enough?
Practical solution.
No, if you cancel the wave out, it is Gone, no more noise.sid_galt said:Aside from the practicality factor, I don't think this will work at all. The two sound waves will cancel each other only in the region where they interact.
Say if the turbine is at point A and the counteracting sound source at point B, then you would again have noise behind point B. Not to mention that you'll have additional noise beyond point A.
Sorry, man, but the noise is an integral part of the 'outflow'. This is nothing like the exhaust from a piston engine. It's a very high volume of hot, fast-moving gas coming through a tuned nozzle. There are all sorts of harmonics and mechanical vibrations to deal with. A moderately sized engine (J-34, as used in drag racers) literally shakes the ground for hundreds of feet around it. The thing in Fred's picture is much smaller, but I bet it's probably at least half as noisy.Lapin Dormant said:As for the outflow of a jet, it is the noise component that is suppressed, not the outflow component,
Lapin Dormant said:No, if you cancel the wave out, it is Gone, no more noise.
Yes I understood that point.Danger said:Sorry, man, but the noise is an integral part of the 'outflow'. This is nothing like the exhaust from a piston engine. It's a very high volume of hot, fast-moving gas coming through a tuned nozzle. There are all sorts of harmonics and mechanical vibrations to deal with. A moderately sized engine (J-34, as used in drag racers) literally shakes the ground for hundreds of feet around it. The thing in Fred's picture is much smaller, but I bet it's probably at least half as noisy.
Interference isn't the goal, cancellation is, then there is no more noise, but, as it is stated above, it would be diffcult, at best, I already knew that, so now, this thread seems to be getting 'hi-jacked' to this topic, so, as to discourage that, I will cease, now.sid_galt said:The noise will only cancel out at the point where the two waves interfere. Beyond that you'll still hear the noise.
Lapin Dormant said:Yes I understood that point.
Thanks
Lapin Dormant said:.. .. ..I will cease now .. .. ..
https://www.physicsforums.com/showthread.php?p=787812#post787812"Lapin Dormant said:If you would like to start a new thread, the waves need be equal and Opposite each other, in waveform.
