What is taken as datum level for the following absolute potentials?
  • Thread starter Thread starter tellmesomething
    Electric Potential
The discussion revolves around determining the datum level for absolute electric potentials derived from electric fields. It highlights that for a hollow sphere, the potential can be calculated using the formula V = Q/(4πε₀x) for points outside the sphere, with the reference point typically taken at infinity where potential is zero. The potential on the axis of a charged disc is given by V = σ√(R²+z²)/(2ε₀), but the reference point for this potential is not clearly defined in the problem statement. Participants emphasize the importance of knowing the reference point to accurately assess the absolute potential. The lack of clarity in the problem set regarding the datum level raises concerns about the correctness of the derived answer.
tellmesomething
Title
None
We take out "formulas" for electric potential from the relation
$$V=\int E.dx$$
Some general formulas are :
For a hollow sphere : ##\frac{Q} {4π\epsilon_0 x}## when x>R, x =distance of that point from the center
And the problem is we just input the distance in sums to calculate absolute electric potential even..
Here its clear if I take datum level as ∞ I get potential as 0. All good
Consider this next potnetial
Potential on the axis of a disc is
$$\frac{\sigma √(R²+z²)} {2\epsilon_0}$$
Where z is the distance from the center of the disc on its axis of symmetry.
What do we take datum level here?
By datum level, I assume that you mean the reference point of the potential at which it is zero.
First of all the expression for the potential function as derived from the electric field is not what you have but $$V(\mathbf r)=-\int_{\mathbf r_{\text{ref}}}^{\mathbf r } \mathbf{E}\cdot d\mathbf r$$where ##\mathbf r_{\text{ref}}## is the point where the potential is taken to be zero.
The book/website/lecture notes where you got this expression probably says where the assumed zero of potential is.
It was in a random problems set, the exact question being " A part of disc of radius R and angle π/6 carries uniformly distributed charge of density ##\sigma##. Electric potential at the centre of the disc is:
I mindlessly used the above derived formula and got the answer which matches the answer given I.e ##\frac{\sigma R}{24\epsilon_0}## . I believe the question asks to find the absolute potential and also has not given us any hint to infer Where the reference level is.. So isnt this answer wrong?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
