What Is the Acceleration of a Cart Connected to a Hanging Block on an Incline?
To determine the acceleration of an 18kg cart connected to a 12kg hanging block on an incline, the relevant forces must be analyzed. The force parallel to the incline was calculated as 101.2 N, while the perpendicular force was 144.5 N. The correct approach involves summing the forces acting on both the cart and the hanging block, applying Newton's second law (F=ma) to find the net force. The expected acceleration is 7.3 m/s², but confusion arises regarding the combination of forces from both blocks. A free body diagram is recommended to clarify the forces acting on each block and to accurately calculate the net acceleration.
polishdude20
An 18kg cart is connected to a 12kg hanging block at the bottom of the incline (ignore friction)
What is the magnitude of acceleration of the cart?
F=ma
Fx=Fgsinx
Fy=FgCosx
well without the hanging weight i calculatoed the force parallel to the plane to be 101.2 N
and the force perpendicular to the plane is 144.5 N
I tried adding the X force (101.2N) to the downward force of the weight on the pulley (176.4 ) and then dividing by the total masses. But I can never get the right answer its supposed to be 7.3 m/s*2 but I don't know how its obtained.
can anyone help?
Try drawing a free body diagram of each block. What forces act on each?
Then use the fact that \Sigma \vec{F} = m\vec{a} to find the net acceleration.
yes i tried that and i don't know do i add the fg of the hanging block to the Fx of the block on the plane?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
