What is the difference between Vrrm and Vrm
  • Thread starter Thread starter yugeci
    Difference
The discussion clarifies the difference between maximum reverse voltage (Vrm) and maximum repetitive reverse voltage (Vrrm). Vrm refers to the highest voltage a device can withstand in a single instance, potentially leading to damage if exceeded. In contrast, Vrrm indicates the maximum voltage that can be repeatedly blocked without causing harm to the device. It is emphasized that normal operating conditions should keep voltage below Vrrm, with Vrm being a concern primarily during fault conditions. Understanding these distinctions is crucial for ensuring the reliability of rectifiers in electrical applications.
yugeci
Hello,
I know peak inverse voltage is the maximum amount of voltage can block, and that it is the maximum value on the negative cycle of the sine wave. But what is the difference between maximum reverse voltage and maximum repetitive reverse voltage? What does the repetitive imply? Does the former mean the maximum voltage that can be blocked in single wave?
The device can block the maximum reverse voltage just once (and probably only for short time). After that has happened, the device may be damaged so it does not meet the rest of its specification.
The maximum repetitive reverse voltage can be blocked repeatedly, any number of times, without causing any damage.
For a rectifier, the normal operating voltage should be less than Vrrm. Usually, Vrm is only relevant if there is a fault, for example if there was a lightning strike that hit the mains power supply and caused a voltage spike.
Likes 1 person
Thanks. That explains it very well.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
