What is the function x(t) for an underdamped oscillating system
For an underdamped oscillating system, the function x(t) is expressed as x(t) = A_0 e^{-t/τ} cos(ω't + φ), where A_0 is the initial amplitude, τ is the damping time constant, and ω' is the damped angular frequency. Initial conditions help determine the phase φ, which is found to be zero when using the position condition. However, when applying the velocity condition, it becomes clear that the exponential decay factor e^{-t/τ} must remain in the equation, as it represents the energy dissipation in the system. The discussion clarifies that underdamped systems do experience exponential decay of amplitude over time, contrary to any confusion with undamped systems. The correct formulation incorporates both the damping factor and the adjusted frequencies.
Damian
and the attempt at a solution[/B]
Approach: Use the solution for the damped oscillating system provided in the formula sheet. We must use the given initial conditions to find the unknown phase ##\phi## and that will give us an expression for ##x## in time. Could use the 'general' solution with the unknowns ##C_1## and ##C_2## but the math seems much harder, so we can use the form below to simplify the calculation.
Since it's underdamped, ##x(t) = A_0 e^{\frac{-t}{\tau}} cos(\omega't+\phi)##
Initial conditions: ##t=0, x = A_0## and ##t=0, \dot x=0##
Using initial conditions: ##A_0 = A_0 cos\phi## so that means ##\phi = 0##
But when using velocity, ##\dot x = 0 = A_0 (-\frac{1}{\tau}cos(0) - sin(0) \cdot \omega'## which would mean that the amplitude and/or damping rate are zero when the parts are stationary.
Does this mean ##x(t) = A_0 e^{\frac{-t}{\tau}} cos(\omega't)##?
Thanks in advance for any help, hints or comments :)
Likes Delta2
The e^{-t/\tau} factor occurs due to the dampening it is the exponential decay of the amplitude as the dampening dissipates the energy. You should leave it out (effectively \tau \to \infty) for the undampened case.
Likes Damian
Thanks for your reply jambaugh.
In this question, it said the system was underdamped - I thought that mean the amplitude does decay exponentially over time. So should I still leave out the e^{-t/\tau} factor?
It was underdamped , not undamped.
http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html
Likes Damian
No, you need the exponential factor. But you should give τ and ω' in terms of γ and ω0.
Likes Damian and Delta2
Oh, My bad eyesight! I read "under" as "un-". Very different case and your approach looks correct qualified with what ehild said. I apologize for my misreading your question. Did that twice now recently.
