What is the least time to get from point ##A## to point ##B##
  • Thread starter Thread starter chwala
    Point Time
The discussion focuses on calculating the least time required for a cyclist to travel from point A to point B, using the equations of motion. The calculated time is 22 seconds, which aligns with the textbook answer. However, some participants express concerns about the lack of units in the equations and the notation used in the calculations. Suggestions are made to analyze the cyclist's motion using a velocity vs. time graph for better clarity. Overall, the approach is validated, but improvements in presentation and notation are recommended.
chwala
A cyclist travels from point ##A## to ##B##, a distance of ##240## metres. He passes ##A## at ##12## m/s, maintains this speed for as long as he can, and then breaks so that he comes to a stop at ##B##. If the maximum deceleration he can achieve when braking is 3 m/s^2, what is the least time in which he can get from ##A## to ##B##?
Velocity and acceleration
My approach;
##v=u+at##
##0=12-3t##
##t=4##
i.e at point when deceleration starts up to the point cyclist stopped (point ##B##).
Therefore, distance travelled in the ##4## seconds is given by,
##s=(12×4)+(0.5×-3×16)=48-24=24##m
##⇒240-24=216##m
##t=\dfrac{216}{12}=18 ##seconds.
Therefore least time taken is ##4+18=22## seconds.
Text book has only given the answer ##22##
your insight or alternative approach is welcome.
Your approach is correct and I would have done it the same way.
Two things I don't appreciate: the lack of units in the intermediate equations and the fact that you have not stated the equation for ##s## you are using. Also ##0.5 \times -3 \times 16## is not proper mathematics, that should be ##0.5 \times (-3) \times 16##.
Try analyzing the cyclist's motion using a velocity vs. time graph.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
