- #36
voko
- 6,054
- 391
Is there any need to approximate anything? We just need to know the sign of the second derivative at ## \theta = 0 ##.
gneill said:Differentiate first. Isolate what you want to solve for, then apply any approximations required. You can also use limits.
voko said:Yes, that is correct. For an extra credit you could try and figure out what happens when ## L = 2R ##.
Pranav-Arora said:I am not sure but I think it won't return to its initial position, it would stay in the same configuration. Right?
Also, does the block perform oscillatory or simple harmonic motion? Is it possible to find the time period of this motion?
voko said:When examining extrema, vanishing of the second derivative is a special case, which requires examining higher order derivatives.
Now that you have PE, you can write down conservation of energy and, using small-angle approximations, get the SHM equation.
Pranav-Arora said:I substituted ##L=2R##. For this value of L, ##U''(\theta)=-mgR\sin\theta ##.
How do I interpret this?
At any instant of time, energy of block is
$$\frac{1}{2}I\omega^2+U(\theta)$$
where I is moment of inertia about CM and ##\omega## is angular velocity of block about CM, am I doing it right?
Yes, very sorry. So ##U'''(0)=-2mgR##.voko said:No. It is ## -mg R \theta \sin \theta ##.
From what I remember, if the third derivative is non-zero, then the point is an inflextion point. I don't understand how to interpret that in the given case.The principle is the same as with the second-order analysis. If the third derivative is not zero, that is not an extremum (why?). If it is, then everything depends on the sign of the fourth derivative, in exactly the same way (why?).
Right, except that you want the moment with respect to the center of the drum, so that the block undergoes pure rotation.
Pranav-Arora said:Yes, very sorry. So ##U'''(0)=-2mgR##.
voko, I don't know why but "pure rotation" about centre of drum does not make sense to me. I can't visualize how it is a pure rotation. The block tips to the right, comes back, tips left, comes back and the cycle goes on, how is it pure rotation about centre of drum? Sorry for asking so many dumb questions.
voko said:No, still not correct. ## U''(\theta) = -mg R \theta \sin \theta \to U'''(\theta ) = - mg R \sin \theta - mg R \theta \cos \theta \to U'''(0) = 0 ##
Those are not dumb questions. The truth is, I was wrong and you are right doubting me. You could instead obtain the KE of CoM motion and the KE of block's rotation about CoM, just like you intended originally.
Pranav-Arora said:Very sorry again, I accidentally posted the value of the fourth derivative at ##\theta=0##.
The fourth derivative is non-zero and negative, so do I say that equilibrium is stable in the case when ##L=2R##?
How do I relate v with ##\omega##? Is ##v=(L/\sqrt{2})\omega##?
voko said:You have already found the location of CoM in terms of the angle. Finding the velocity from that should be straight forward.
h is the height of CoM as shown in gneill's sketch in post #25.voko said:What is ## h ##?
I was referring to the following formula of the CoM position: ## (R + L/2) \vec u - R \theta \vec t ##, where ##\vec u## is the unit radial vector, and ##\vec t## is the unit tangent vector, as explained earlier. The CoM velocity, then, is ## v_c = (R + L/2) \dot {\vec u} - R \dot \theta \vec t - R \theta \dot {\vec t} = (R + L/2) \vec t \dot \theta - R \dot \theta \vec t + R \theta \vec u \dot \theta = (L/2) \vec t \dot \theta + R \theta \vec u \dot \theta ##, and ##v_c^2 = (L^2/4 + R^2 \theta^2) \dot \theta^2 ##
Pranav-Arora said:$$v_y=\frac{dh}{dt}$$
$$v_x=\frac{d}{dt}\left(\frac{L}{2}\sin\theta\right)$$
where ##v_x## is the horizontal velocity of block and ##v_y## is the vertical velocity of block.
I can replace ##\omega## with ##d\theta/dt##.
Am I correct?
voko said:By the way, if you think that the x-position of the CoM is ## \frac{L}{2}\sin\theta ##, you are mistaken
Can you please tell me how do you find the horizontal and vertical components?(this is obvious from the vector formula).
Pranav-Arora said:Are the following correct?
$$\vec u=\sin\theta \hat{i}+\cos\theta \hat{j}$$
$$\vec t=\cos\theta \hat{i}-\sin\theta \hat{j}$$
voko said:Have you found the period of small oscillations?
voko said:KE has the form ## K(\theta) \dot \theta^2/2##. It is approximated with the lowest non vanishing order, which is simply ## K(0) \dot \theta^2/2 ##.
I already understood this but what I don't get is the following:voko said:In #54, kinetic energy was shown to be ## \frac{1}{2}m\dot{\theta}^2\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM}\dot{\theta}^2 ##. This can be written as ## \left[\frac{1}{2}m\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM}\right]\dot{\theta}^2 = K(\theta)\dot \theta^2##, so ## K(\theta) = \frac{1}{2}m\left(\frac{L^2}{4}+R^2\theta^2\right)+ \frac {1}{2}I_{CM} ##.
You approximate using Taylor expansion at ##\theta=0##, right?Now we approximate ## K(\theta) ## with just ## K(0) ##.
I will have a look at them soon if they are available in my country. :)I have checked what Kleppner has to say on small oscillations, and found that lacking. The form of the kinetic energy they have has no dependency on the coordinates, only on velocities, so there is no demonstration how to proceed in a case like you have here, even though it is taken from that same book.
Symon and Goldstein do a far better job at explaining that; Landau is also noteworthy.
voko said:Looking good!
voko said:You did a lot more than the problem required.
