- #71
Zafa Pi
- 631
- 132
I'm having difficulty following, but I think I can get it with some more thought.edguy99 said:Absolutely I agree on the reason they do it. But.. by doing this they are assuming the the photon obeys the Bell assumption that entangled photons will match no matter the angle they are measured at. Assume that the polarization is represented by the normalized Jones vector.
By introducing a "wobble", we can make some sense out of the QM fact that these polarization are only the "best guess" (amplitude of probability if you like) of what you will measure the polarization as. QM tells us that if you create a vertical photon, you will alway detect a vertical photon if measured vertical. But if you create a vertical photon and measure it an a different angle (say 45 degrees), the result is probabilistic, as if there was a wobble in the orientation. The point is that a photon with a wobble, will not match the starting conditions of a Bell Test since Bob and Alice are not guaranteed to get matches when photons are measured off of their basis vectors. But a photon with a wobble will match QM if we do not use the entangled pairs that do not match at weird angles as many experiments do.
I don't understand the ket notation a1 + a2i|x>: a1 is a number, a2i|x> is a vector, how do you add the two?
