What is the physical significance of Bell's math?
In summary: Bell's theorem applies to all classical settings known to me. Full stop.3. Finally, a question: You say "once you accept (14a), (14b) follows whether you are using sums or integrals". But does the same hold for (14c)?In summary, the conversation discusses Bell's theorem and its application to classical settings. The theorem applies to any setting that satisfies the assumption [A(b,λ)]2 = 1, and since all classical settings satisfy this assumption, Bell's theorem applies to all classical settings. Additionally, it is mentioned that once (14a) is accepted, (14b) follows regardless of whether sums or integrals are used.
  • #106
stevendaryl said:
Maybe this depends on how you define "entanglement", but the definition I've used is that two particles are entangled if they are described by a two-particle wave function that cannot be "factored" into a product of one-particle wave functions. So it's a theoretical description of what goes on in EPR. If QM is false, then so is the description of the particles as "entangled".
You are giving the QM definition, and I agree with it. However, via various processes (e.g. down conversion) entangled photons are created in nature, and with the measuring devices (polarization analyzers) give the same weird results predicted by QM., thus independent of whether quantum mechanics is the ultimate theory, or not.
  • #107
Zafa Pi said:
syn·on·y·mous
səˈnänəməs/
adjective
  1. (of a word or phrase) having the same or nearly the same meaning as another word or phrase in the same language.
    "aggression is often taken as synonymous with violence"
    • closely associated with or suggestive of something.
      "his deeds had made his name synonymous with victory"
By that definition of "synonymous", I don't think that any two of "entanglement", "FTL" or "local" are synonymous.
It doesn't.
However, I did define locality as no FTL
Fine. I don't think that's a helpful definition, though. I agree that QM does not provide a way for people to communicate FTL. I think everybody agrees with that. If that's the end of the matter for you, then there is no need to further discuss Bell and EPR.
  • #108
Yes, I would just say that the predictions of QM in EPR-type experiments have been verified, so any successor theory must make the same predictions for those experiments. I would not say that a successor theory must have entangled particles.
  • #109
morrobay said:
If Bell inequality is violated, of the three possibilities: non locality (FTL), non realism, contextual I would favor contextual
Can you give me a short, simple example or explanation that distinguishes nonrealism (= nonCFD) from contextual?
  • #110
It doesn't.
Neither do I. This is disheartening, you've missed which two concepts I've claimed were synonymous. I presume you didn't read either post #91 or #100. I feel crushed.:frown:
You don't care for my definition of local. What do you prefer?
  • #111
No , nonCFD is equated with or subset of contextuality : Measurement outcomes are produced from particle/detector field interactions.
  • #112
Cool, I understand your whole sentence. So now all you have to do to make me a happy quantum camper is to give me an example of contextuality that isn't nonCFD.
The classic example of contextually is the Mermin-Peres quantum pseudo-telepathy, but that is also nonCFD.
If you can't provide me with such an example, I hereby threaten to say they are synonymous, just like I did with Bell non locality and measurements on entangled entities, thus earning further derision from PF luminaries.
  • #113
Everyone, please bear in mind that this is an I level thread and some math is expected. Throwing around ordinary language terms without giving them precise mathematical definitions is a recipe for endless discussion with no resolution, and eventually either a closed thread or a warning. This thread is getting close to the latter point now.
  • #114
For a quantitative example/explanation let's let one of the Masters or PhD's in physics take your question. My background is in Biology/Chemistry and I am not qualified to go any farther with this.
  • #115
I notice a while back there was a B level thread on exactly this topic. However, no answers were provided.
  • #116
Post #91 is where you said
Your definition of non-locality in #74 is synonymous with the existence of entangled particles
I specifically said that I disagreed with that statement. You also said:
Do the correlations that are manifest in measuring entangled pairs require FTL phenomena
I specifically said that I don't think so.
So I read your post #91 and specifically responded to it. So don't feel crushed.
I wrote a very detailed post, complete with a diagram that I spent a good part of an hour creating, several years ago, in an attempt to answer that question. Let me try one more time.
A "nonlocal correlation" is a correlation between distant (spacelike separated) events. A local theory (or model) explains or implements all nonlocal correlations in terms of a chain of two or more local correlations. So in a local theory, if A is correlated with B, then either A is in the causal past of B, or B is in the causal past of A, or there is a set of events C1, C2, ... such that all the Cs are in the causal past of both A and B and A is only correlated with B through its correlations with C1, C2, ...
The events C1, C2, are elements of the model---they aren't necessarily directly observable.
What's an example of a nonlocal model, then? Well, here's a toy example. Suppose there is a pair of coins, and I propose the following theory about those coins: The nth flip of one coin always produces the opposite result of the nth flip of the other coin.
That's a falsifiable theory about those coins. You can certainly test it by just flipping the coins a bunch of times. But it's a nonlocal theory, since it predicts a correlation between possibly distant coins and does not explain or implement the correlation in terms of local correlations.
In this case, I could come up with a different, local theory that made the same predictions as the first theory. But the original theory is nonlocal.
I believe that in the same way, quantum mechanics in the standard way that it is applied is nonlocal. Einstein et al believed that there might be a local theory that made the same predictions as quantum mechanics, but Bell proved them wrong.
Likes Boing3000
  • #117
When I said, "Neither do I. This is disheartening, you've missed which two concepts I've claimed were synonymous. I presume you didn't read either post #91 or #100."
I was referring to your comment,
And it appeared that you were misquoting me. I'm sorry I made you go through that again. I did understand your post #74. I feel uncrushed.
It seems that your definition of local (post #116) is the negation of your nonlocal, as it should be. Whereas my definition of nonlocal is the negation of local (post #54).
That our definitions disagree is ok with me. We've each said what we dislike about the other's definitions.
You did clear up Bell's definition for me that he made in OP's cited paper, to wit:
"It is the requirement of locality, or more precisely that the result of a measurement on one system be unaffected by operations on a distant system with which it has interacted in the past", which I found vague.
I'm sorry you hate CFD, I hope it doesn't feel crushed.
  • #118
It's just that I don't think it clarifies anything. A local, nondeterministic theory violates CFD, so violating CFD is not a big deal, it seems to me, and it doesn't do anything to understand the difference between a quantum theory and a classical theory.
Likes Jilang and Mentz114
  • #119
Thanks for this. The OP was intended to be a straight-forward (but highly relevant) question and I do not see that it has been satisfactorily answered. In my view, without Bell's assumption, his theorem fails. If he was mimicking EPR, then EPR fails. But I do not see that the failure of EPR would mean the failure of local realism.
Maybe a clearer example of my concern is this attachment from Isham's "Lectures on Quantum Theory" (1995). More recent examples exist.
In Isham's equation (9.33), he sums over the same set of particles on 4 occasions! It would never occur to me to do that: for, if I did , I would expect to get an outcome that applied to objects that I could meaningfully test 4 times. Classical objects would meet this criteria; quantum objects would not. So back to my question in the OP please.
  • Isham (1995), eqn (9.33).pdf
  • #120
They don't have to be the same objects; they just have to be taken from an ensemble of objects all prepared in the same state.
  • #121
It seems to me that this answer leaves me with my original difficulty with Bell's workings. I agree that, given 4N objects prepared in the same state, the average of each of the 4 terms in RHS (9.33) would be unchanged when each is tested over N runs. For example, under EPRB, the first such RHS term would reduce to -a.b; and so on.
But (9.33) is based on the an appearing again in the second term on RHS; the bn appearing again in the third term on RHS; etc. So the problem (that I am wrestling with) goes back to eqn (9.32). There we see 4 pairs of terms created from 4 terms; I say that there should be 8 terms. For how is it possible to match the a in the first pair with the a result in the second? For in one run it may be +1, in the next -1.
This seems to be recognised by Isham in the 2nd paragraph: "The central realist assumption we are testing is that each particle has a definite value at all times in any direction of spin. We let an denote 2/h times the value of a⋅S possessed by particle 1 in the n'th element of the collection. Thus an = ±1 if a⋅S = ±h/2".
How can particle 1 in the n'th element be tested twice?
NB: As a local-realist, that "central realist assumption" has no place in my thinking: for surely it is false?
  • #122
It can't, but the "central realist" assumption Isham is describing amounts to the claim that particle 1's spin direction is a hidden variable which has a definite value whether it is measured or not, and can therefore be used to predict/model what the results would have been to measurements that were not actually made. Other sources call this "counterfactual definiteness" or similar names.
Whether that assumption makes sense to you is of course your own choice. But mathematically it is perfectly clear and Isham is simply calculating its implications.
  • #123
OK; thank you. Referring then to the OP: Do we agree then, that this is the same assumption that Bell made to move from his (14a) to his (14b)?
In other words: Is Isham (1995) simply calculating the same implications as in Bell (1964)?
If that were the case, I'm surprised that so many claim that Bell is definitive against "local realism" in general -- without spelling out that Bell's theorem is based upon (and therefore limited to) that naive (in my view) "central realist" assumption.
PS: Not wishing to change the subject but seeking to be very clear on this pesky subject: I understand that my views are compatible with QFT. So again, at that advanced level, Bell's theorem seems to be irrelevant?
  • #124
As far as I can tell, yes.
How would you mathematically express "local realism" as opposed to "central realism"?
  • #125
It's worth noting, though, that Bell defines "local realism" in his paper by an earlier equation, the one that says the probability ##P(a, b, \lambda)## must factorize into ##P(a, \lambda) P(b, \lambda)## (I can't remember exactly which equation this is in his paper and don't have it handy to check). The equations you are talking about are derived from that original assumption. And that original assumption is already violated by the QM probabilities.
  • #126
PeterDonis said:
… How would you mathematically express "local realism" as opposed to "central realism"?
Thanks for the good question: My preliminary opinion follows, based on Bell (1964), which we denote by E (for the crucial EPRB experiment).
Locality: A(a, λi) = ±1; B(b, -λi) = ±1. (1)
Therefore: B(b, -λi) = -A(b, λi). (2)
Realism: Bayes' Rule (which is never false) is relevant to (1) since A and B are independent per (1), but correlated per (2) and the correlated elements in (1).
Therefore: P(AB|E) = P(A|E)⋅P(B|EA) = P(B|E)⋅P(A|EB). (3)
As you say, and I agree: Bell's original probability assumption -- which is not (3) -- is already violated by the QM probabilities.
Note that (3) is a logical implication from (2): it should not be confused with (and has no relation to) causation, signalling, piloting, etc. Thus, for me, (3) is fundamental to a realist view of the world in the presence of correlations; especially when such correlations derive from the conservation of total angular momentum in the generation and emission of each and every particle-pair in EPRB. In my view, it is unrealistic to negate (3) given (1) and (2).
IMHO, putting it another way: To reason contrary to (3), as Bell does, is to not make proper use of the entanglement brought about by the conservation rules that apply in EPRB.
To be clear re logical implication: If Alice and Bob know that I am distributing numbered pairs of Red ribbons and numbered pairs of Blue ribbons, logical implication allows each to know what the other receives (by colour and number). Here, again, there is no causation involved -- just initial correlation at the source (which is me in this classical analogy). In the quantum case (EPRB), I know how the emitted-pairs are more cleverly correlated.
  • #127
I don't understand what this means. The ##\lambda_i## are supposed to be hidden variables, which means we don't know their values, so how can this be tested?
Also, why should the values A and B only be 1 or -1? They are supposed to be probabilities, right?
Also, even leaving that aside, why does this express locality?
I don't see how this follows from (1).
I don't see how this follows either. Bayes' rule is completely general.
  • #128
We know the results A and B from experiment; we know a and b. We don't know the λ's beyond knowing that they are anti-correlated.
A and B are the results (outcomes), per Bell (1964), eqn (1). They are not probabilities.
Outcome A is in Alice's location, as is the detector-setting a; as is each particle-property λ of each particle that she tests. Same for Bob. So the outcome events (the analysers locally signalling ±1) are local and spacelike separated..
See similar at Bell (1964), eqn (13).
Bayes' Rule is general, and applicable here. And here it remains in its non-reduced form because the outcomes are correlated.
  • #129
CFD is derived from following:
Outcomes are determined : A (a,b,λ) = ± 1, B( a,b,λ) = ± 1
Locality: A (a,λ) = ± 1 , B (b,λ) = ± 1
The perfect anti correlations along same axis : A (b,λ) = - B ( b,λ)
Then it follows: E ( a,b ) = - ∫ d λ p (λ) A ( a,λ) A (b λ)
That includes determinism and is a classical concept..
Contextuality is an orthodox QM viewpoint: The measuring apparatuses define the conditions and outcomes. Outcomes are not pre- encoded in measured object but only arise in interaction of object and detector fields. In accord with Kochen - Specker Theorem
CFD is only compatible with the orthodox view when detectors are aligned. However when settings a, b, and c are included as random variables on classic probability space - they are static properties and invalid contextually.
So I can only distinguish CFD from contextuality.
Reference, equations 1-7 https://arxiv.org/pdf/quant-ph/0606084.pdf
  • #130
For the sake of clarity, let me reproduce the equations we're talking about:
[itex]g_n = a_n b_n + a_n b_n' + a_n' b_n - a_n' b_n'[/itex] (9.32)
[itex]\frac{1}{N} |\sum_n g_n| = \frac{1}{N} |\sum_n a_n b_n + a_n b_n' + a_n' b_n - a_n' b_n'|[/itex] (9.33)
What I think you're complaining about is that, since Alice (one of the experimenters) can only measure at most one of [itex]a_n[/itex] or [itex]a_n'[/itex] and Bob (the other experimenter) can only measure at most one of [itex]b_n[/itex] or [itex]b_n'[/itex], there is no way for them to measure [itex]g_n[/itex], since it involves all 4 values. Is that your complaint?
But at the end, we're averaging over all runs, so the fact that not all 4 measurements came from the same run does not make a difference (unless one of a number of loopholes is exploited---I'll get to those later).
First of all, Bell is assuming that the measurement results are deterministic functions of the hidden variables and the measurement choices. So in each run of the experiment, all 4 variables--[itex]a_n, a_n', b_n, b_n'[/itex]--have definite values, even though Alice and Bob can only measure two of them.
So taking into account your complaint, what is actually measured, through many rounds of the experiment, is not
[itex]\langle g \rangle \equiv \frac{1}{N} \sum_n g_n[/itex]
What is actually measured is four separate numbers:
  1. [itex]\langle a b \rangle \equiv \frac{1}{N_1} \sum_{n,1} a_n b_n[/itex]
  2. [itex]\langle a b' \rangle \equiv \frac{1}{N_2} \sum_{n,2} a_n b_n'[/itex]
  3. [itex]\langle a' b \rangle \equiv \frac{1}{N_3} \sum_{n,3} a_n' b_n[/itex]
  4. [itex]\langle a' b' \rangle \equiv \frac{1}{N_4} \sum_{n,4} a_n' b_n'[/itex]
Where
  • [itex]\sum_{n,1}[/itex] is the sum over all [itex]n[/itex] such that on round number [itex]n[/itex], Alice measured [itex]a_n[/itex] while Bob measured [itex]b_n[/itex],
  • [itex]N_1[/itex] is the number of such rounds
  • [itex]\sum_{n,2}[/itex] is the sum over all [itex]n[/itex] such that on round number [itex]n[/itex], Alice measured [itex]a_n[/itex] while Bob measured [itex]b_n'[/itex],
  • [itex]N_2[/itex] is the number of such rounds
  • etc.
So we don't actually measure [itex]\langle g \rangle[/itex]. But the point is that under certain assumptions about random variables, we will have:
[itex]\langle g \rangle = \langle a b \rangle + \langle a b' \rangle + \langle a' b \rangle - \langle a' b' \rangle[/itex]
What are those assumptions? Basically, that each round, the four numbers [itex]a_n, b_n, a_n', b_n'[/itex] are produced with consistent probabilities, independent of the round number, and independent of which of the four Alice and Bob actually measure.
Likes PeterDonis
  • #131
Some people have said this, and I think it's wrong. QFT is not a local realistic theory any more than nonrelativistic QM is. It violates Bell's inequality in the same way that nonrelativistic QM does. So whatever implications Bell's theorem has for nonrelativistic QM, it has the same implications for QFT, namely that there is no local realistic theory that makes the same predictions (well, unless you go for something weird like Many-Worlds or superdeterminism or back-in-time causality).
Likes zonde and PeterDonis
  • #132
How do we know they are anti-correlated? Bell does not assume that; in fact he assumes the opposite (see last comment below).
Ah, ok. But then eqn (2) of that paper expresses locality in terms of things we can actually observe; we don't observe the hidden variables ##\lambda##.
Bell's eqn (13) is
A(a, \lambda) = - B(a, \lambda)
Note the key difference: his ##\lambda## has the same sign on both sides of his equation. Your ##\lambda## has opposite signs on the two sides of your equation. So your equation contradicts Bell's, yet they are both supposed to be derived from the same premises. Why is yours right and his wrong?
  • #133
That is not my "complaint" -- please see next.
Where
  • etc.
In my terms, which I trust are accurate: Without any assumptions, what is actually derived from measurements is four separate expectations:
  • (1) [itex]\langle a b \rangle \equiv \frac{1}{N_i} \sum^{N_i}_1 a_i b_i[/itex]
  • (2) [itex]\langle a b' \rangle \equiv \frac{1}{N_j} \sum^{N_j}_1 a_j b'_j[/itex]
  • (3) [itex]\langle a' b \rangle \equiv \frac{1}{N_k} \sum^{N_k}_1 a'_k b_k[/itex]
  • (4) [itex]\langle a' b' \rangle \equiv \frac{1}{N_l} \sum^{N_l}_1 a'_l b'_l[/itex]
So, please: What assumptions are you making to modify these equations?
My problem (not so much a complaint) is that I can see no valid basis for modifying these equations; which are valid both classically and quantum mechanically.
From the OP, it is my belief that Bell's work [and the given mathematical assumption that he makes in moving from his (14a) to his (14b) in the context of EPRB (a QM setting)], limits his results to those delivered in classical settings.
  • #134
Didn't I just go through that in my post? We use
[itex]\langle g \rangle = \langle a b\rangle + \langle a b'\rangle + \langle a' b\rangle - \langle a' b'\rangle[/itex]
It's a valid move if each "run" of the experiment is independent, and the probabilities are constant.
Nobody's modifying anything, we're just using the mathematics of probability to derive a fact about the correlations.
  • #135
It's a valid move if each "run" of the experiment is independent, and the probabilities are constant.Nobody's modifying anything, we're just using the mathematics of probability to derive a fact about the correlations.
The reason that I spelt out the valid equations (1)-(4) is because I want to be clear as to what you are doing. I believe your response makes my questioning even clearer: You seem to be agreeing that we can use my equations (1)-(4) in
[itex]\langle g \rangle = \langle a b\rangle + \langle a b'\rangle + \langle a' b\rangle - \langle a' b'\rangle[/itex]. (5)
But, as in the Isham pages that I posted (p.182; and as is customary), how do you now maintain that:
|[itex]\langle g \rangle[/itex]| ≤ 2; (6)
since each expectation in my equations (1)-(4) lies in the range ±1?
That is: |[itex]\langle g \rangle[/itex]| ≤ 4; (7)
with a maximum of 2√2 under EPRB. That's why it's not clear to me when you say: "Nobody's modifying anything, we're just using the mathematics of probability to derive a fact about the correlations." What "mathematics of probability" please?
  • #136
You're asking about a mathematical proof that has been proved many times. What exactly did you not understand about that proof?
Really, you're questioning something that is mathematically provable. So it's really mathematics, rather than physics.
  • #137
But they are not independent. ##|g| \le 4## assumes they are independent. When you take into account the correlations between them, given the assumptions, you have ##|g| \le 2##.
  • #138
Bell's eqn (13) is
Mine is right and Bell's is right because they are each correct and equivalent. Using your example
$$A(a, \lambda) = - B(a, \lambda) = B(a, -\lambda').$$ I associate the HVs with the conservation of total angular momentum and choose to be clear about which HV (in Bell's notation) that I am referring to. Thus:
$$ \lambda_i + \lambda'_i = 0 $$where, on the i-th run of the experiment, the former is the HV that Alice receives and the latter is the HV that Bob receives. It's my understanding that, in QM, the equivalent expression is:
$$ \sigma_1+ \sigma_2 = 0 $$where the subscripts denote Alice's particle and Bob's particle, respectively.
  • #139
Once again, we have:
We rearrange it as follows:
[itex]g_n = a_n (b_n + b_n') + a_n' (b_n - b_n')[/itex]
Since [itex]b_n[/itex] and [itex]b_n'[/itex] are each [itex]\pm 1[/itex], it follows that either
  • Case A: [itex]b_n + b_n' = 0[/itex] (if they are opposite signs), or
  • Case B: [itex]b_n - b_n' = 0[/itex] (if they are the same sign).
So in Case A,
[itex]g_n = a_n' (b_n - b_n') = 2 a_n' b_n = \pm 2[/itex]
In Case B,
[itex]g_n = a_n (b_n + b_n') = 2 a_n b_n = \pm 2[/itex]
So in either case, [itex]g_n = \pm 2[/itex].
If for every single [itex]n[/itex], [itex]g_n = \pm 2[/itex], then obviously the average value of [itex]g_n[/itex] must be in the range [itex]-2 \leq \langle g \rangle \leq +2[/itex].
We agreed earlier that
So putting those two facts together, we get Bell's inequality (or actually, the CHSH inequality)
[itex]-2 \leq \langle a b \rangle + \langle a b' \rangle + \langle a' b \rangle - \langle a' b' \rangle \leq +2[/itex]
  • #140
PeterDonis said:
But they are not independent. ##|g| \le 4## assumes they are independent. When you take into account the correlations between them, given the assumptions, you have ##|g| \le 2##. Emphasis added.
But my equations (1)-(4) are independent. And the limit of 2√2 is achievable with such independent equations.
It is your assumptions that I am seeking to understand: the assumptions that you need to make to those equations (1)-(4) in order to establish the limit of 2 that you accept.
This all goes back to the OP where I sought to understand the physical significance of Bell's mathematical assumption that linked his (14a) to his (14b).
