What is the Relationship Between R, v0, θ, and d in Projectile Motion?
  • Thread starter Thread starter bullet_ballet
    Figure
The discussion focuses on the relationship between the range (R), initial velocity (v0), launch angle (θ), and height (d) in projectile motion. The user initially attempts to derive the equation R sin2θ + d (1 + cos2θ) = R²/R0 but struggles with the calculations, particularly in determining the horizontal distance covered during the drop. A key error identified is the incorrect use of the equation for vertical motion, where the projectile's initial vertical velocity should be negative during the fall. After correcting this mistake, the user successfully manipulates the terms to reach the desired relationship. The exchange highlights the importance of accurate sign conventions in projectile motion calculations.
bullet_ballet
Please bear with my verbosity on this one, and with the messy symbols.
The problem states that I am to fire a projectile from some distance d above the ground (ignoring air resistance) with initial velocity v0 and initial angle θ. I am to show that between R (the maximum horizontal distance), v0, θ, and the drop d there is a relationship R sin2θ + d (1 + cos2θ) = R²/R0 where R0 ≡ v0²/g.
Well, the way I see it the range has two parts. The first part is the range R1, the horizontal distance the projectile covers in going from y=d to some ymax and then falling back to y=d. This is given by the normal
(v0² sin2θ)/g. Then one should have to calculate the horizontal distance covered by the drop from y=d to y=0, which is simply R2=v cosθ t', where t' is the time it takes for the ball to drop from y=d to y=0. Well, at y=d the object should have velocity v0 and be falling at angle θ. To find t' I use the formula y=y0 + v0 sinθ t' - ½ g t'². Plugging in y=0 and y0=d and using the quadratic formula I get that:
t' = [v0 sinθ ± √(v0² sin²θ + 2gd)]/g.
Now, adding R1 and R2 to get R, I obtain:
R = R1+R2 = (v0² sin2θ)/g + (v0² sin2θ)/2g - [v0 cosθ √(v0² sin²θ + 2gd)]/g
or R = (3 v0² sin2θ)/2g - [v0 cosθ √(v0² sin²θ + 2gd)]/g
Well, I can't manipulate that equation to get the necessary relationship, and in a related problem utilizing the above equation didn't give me the correct answer (they asked for an maximizing angle and a v0).
The logic seems pretty sound to me, so what am I doing wrong? I've been agonizing over this for hours, so any help is appreciated.
Welcome to PF!
One obvious mistake you've done is in your calculation of R2:
"at y=d the object should have velocity v0 and be falling at angle θ. To find t' I use the formula y=y0 + v0 sinθ t' - ½ g t'²."
The projectile is FALLING, not RISING!
Hence, surely, you must use:
y=y0-v0sin(theta)t'-1/2gt'^2
(I haven't checked the rest yet)
Note:
The formula you use is valid from the initial point, i.e, when the projectile is shot upwards.
Thanks for the reply!
I can't believe I made such a basic mistake. With that sign change, I'm able to manipulate the terms and obtain the final answer. Much appreciated.
