What is the spring constant of spring?
The discussion revolves around calculating the spring constant for a scenario where a 60 kg person drops onto a spring-supported platform. The initial calculation used only the height of 1.20 m, but it was clarified that the total drop includes an additional 0.06 m due to the spring's compression. The correct formula to use is derived from energy conservation, equating gravitational potential energy to spring potential energy. The final calculation should incorporate the total drop of 1.26 m, leading to a revised spring constant of approximately 4.12 x 10^5 N/m. Understanding the total distance fallen is crucial for accurate results in such physics problems.
Mdhiggenz
324
A 60 kg person drops from rest a distance of 1.20 m to a platform of negligible mass supported by a stiff spring. The platform drops 6 cm before the person comes to rest. What is the spring constant of spring?
w=1/2kx^2
mgh=1/2kx^2
2(mgh)/x^2=k
2(60kg*9.8*1.20)/0.06m=3.92*10^5
the answer however is 4.12*10^5
What am I doing wrong?
Thank you
The mass falls further than 1.20 as the spring compresses.
So would I add the 0.06m? Iam a bit confused
Correct. :smile:
The question says …
… after that it drops a further 0.06 m, so the total drop (for the person) is 1.26 m :wink:
Thx Tim
