What is the value of F_max for an impulse of 6.8 Ns in the given figure?
  • Thread starter Thread starter krej
    Impulse
The discussion revolves around calculating the maximum force (F_max) required to achieve an impulse of 6.8 Ns, based on a provided figure. Initial attempts included integrating force over time and calculating the area of a triangle, both of which yielded incorrect results. The key insight revealed that the time axis is in milliseconds, leading to the correct equation: 4x10^-3 * F_max = 6.8. This adjustment shows that F_max equals 1700 N, highlighting the importance of unit awareness in calculations. The conversation emphasizes the need to carefully consider units in physics problems to avoid errors.
krej
In the figure , what value of F_max gives an impulse of 6.8 Ns?
http://img76.imageshack.us/img76/1782/09ex05.jpg
Integral of F with respect to time equals impulse
I tried doing two things, and they were both wrong.
First, i tried the integral of F with respect to time from 0 to 8 = 6.8.
Ft from 0 to 8 = 6.8
F(8) - F(0) = 6.8
F = 6.8/8
F = 0.85
I realize that is wrong though, since the picture they give us isn't of constant force.
So then I tried using the area of a triangle:
Area = (1/2)b*h
Area = (1/2)*8*h
4h = 6.8
h = 6.8/4 = 1.7
So I entered 1.7 into the website, and it said it was wrong. If that didn't work, I have no idea what else I could do to find it.
F(8) - F(0) = 6.8
F = 6.8/8
F = 0.85
Area = (1/2)b*h
Area = (1/2)*8*h
4h = 6.8
h = 6.8/4 = 1.7
Note that the units on the time axis are miliseconds. Hence, 4x10^-3*Fmax==6.8, Fmax==1700N.
Oh, wow I didn't notice that at all. I'm too used to it always being in seconds I didn't even think about looking at that. :p
Thanks a lot for your help!
