What is the wavelength of the sound waves?
The discussion centers on determining the wavelength of a sound wave given the distance between nodes. The distance between the first and sixth node is 30.0 cm, leading to the realization that there are five segments between six nodes. The correct calculation shows that the wavelength is found by using the formula λ = (2/5)L, resulting in a wavelength of 12.0 cm. Participants suggest visualizing the problem with a diagram to clarify the relationships between nodes and wavelength. Ultimately, the correct solution is confirmed as 12.0 cm.
look416
a stationary sound wave has a series of nodes. The distance between the first and the sixth node is 30.0 cm. What is the wavelength of the sound waves?
well no idea about it
but in my attempt to solve it, i tried assuming 2L = \lambda
but there are 6 nodes so \lambda = \frac{1}{3}L
by substituting the value of dist, i get \lambda = 10cm
which is wrong. the ans is 12.0 cm
i wonder how to solve it
Try drawing yourself a diagram of the problem (ie just draw a wave going through six nodes), you should be able to solve it a bit more easily once you can visualise it.
Your current working is neglecting the fact that there are two nodes at either end of this hypothetical wave. (kind of analogous to a similar problem you are probably familiar with - ie if a farmer had 100m of wire to build a fence and he could place the posts 2m apart, how many posts would he need?)
i think i know it
probably i should count the between one
so it should be \frac{2}{5} L = \lambda
by computing it
i get 12.0 cm
yeah
thx all of you
  • · Replies 19 ·
