What percentage of the total mass of the pendulum is in the uniform thin rod?
The discussion revolves around calculating the percentage of the total mass of a pendulum that is attributed to a uniform thin rod, given that the pendulum is modeled as a combination of this rod and a point mass. The period of the simple pendulum is calculated to be 2.08 seconds, but Christy observes that her clock's pendulum is 1.20% faster. Participants suggest using torque equations and moment of inertia to analyze the contributions of both the rod and the point mass. The need for a clear equation to relate mass, torque, and angular velocity is emphasized. The conversation highlights the complexity of the problem and the importance of understanding the dynamics of the pendulum system.
jayced
Christy has a grandfather clock with a pendulum that is 1.070 m long.
(a) If the pendulum is modeled as a simple pendulum, what would be the period?
Already solved
(b) Christy observes the actual period of the clock, and finds that it is 1.20% faster than that for a simple pendulum that is 1.070 m long. If Christy models the pendulum as two objects, a 1.070-m uniform thin rod and a point mass located 1.070 m from the axis of rotation, what percentage of the total mass of the pendulum is in the uniform thin rod?
Need help
(a) T=2pi sqrt(L/g)
(b) Couldn't find an appropriate equation in my textbook.
(a) T=2pi sqrt(1.070m/9.8m/s^2)=2.08 s
(b) I don't have a clue about the equation that correspond to this part of the problem,no similar examples or anything in my textbook. To start a equation would be great, because I have percentages and meters and they want me to calculate total mass of a pendulum. Any help is great thank you.
My solution is: denoting mass of thin rod is m1 and point mass is m2.
==> torque eq: \tau = I \alpha
The contribution to torque is due to rod and point mass and similarly for I. Plug them into above eq and use small angle theta to find alpha. You also know that, alpha = -(omega)^2 * theta => you have angular velocity omega and T = 2*pi / omega => percentage
Hope this helps.
  • · Replies 31 ·
