B What will be the ball's velocity after a perfectly elastic collision?
In a perfectly elastic collision involving a ball and a moving bus, the ball's initial velocity is affected by the bus's motion, resulting in a new velocity that is not simply the negative of the initial. The discussion highlights the importance of using conservation of momentum and energy to derive the new velocities, leading to the conclusion that the ball's final velocity is influenced by both its initial speed and the bus's speed. It is emphasized that choosing an appropriate frame of reference simplifies problem-solving. The analogy of a tennis ball thrown from a moving train illustrates how momentum transfer occurs during collisions. Understanding these principles is crucial for accurately determining the ball's velocity post-collision.
Lotto
TL;DR Summary
I throw a ball with a velocity ##v## against a bus moving towards me with a velocity ##-u##. What will be the ball's velocity after a perfectly elastic collision?
From the bus driver's point of view, who is at rest, the ball's initial velocity is ##u+v##. After the collision, its velocity has to have the same value, but an opposite direction, so ##-(u+v)##. So that means that relative to me standing on the ground at rest, the ball's new velocity is ##-(v+2u)##.
I understand this, but how to derive the new velocity from my point of view? I still can't explain why it is ##+2u## instead of ##+u##, I mean that the new velocity isn't##-(u+v)##. How to explain it? It is clear that it is because of the moving bus, but why in particular?
You can just write down the conservation of momentum $$mv-Mu=mv_f-Mu_f$$ and the conservation of kinetic energy $$\frac{1}{2}mv^2+\frac{1}{2}Mu^2=\frac{1}{2}mv_f^2+\frac{1}{2}Mu_f^2$$ That is two equations in two unknowns, so you can solve it to get $$u_f=\frac{Mu-m(u+2v)}{m+M}$$$$v_f=\frac{mv-M(2u+v)}{m+M}$$ Then we simply take the limit as ##M\rightarrow \infty## to get $$u_f=u$$$$v_f=-2u-v$$
Likes Lotto and Frabjous
You can do the first case in your head because you know the solution for an object hitting a stationary infinite mass. You do not know the solution for a moving object hitting a moving infinite mass, so you have to go back to first principles and use conservation of momentum and energy for the second case. This is an example of why choosing a “smart” frame of reference can make solving a problem easier.
Likes Lotto and Dale
Can you explain why it should be ##-(u+v)##? It doesn't make any sense, because for ##v=0## the ball would just remain stuck to the bus, which isn't an elastic collision.
To check solutions it often helps to consider limiting / extreme cases.
Likes phinds, jbriggs444 and Dale
Not very long ago there was a heated thread about gravity-assisted maneuvers where something very similar came up. This might help you.
From the article
Another analogy, illustrated by the cartoon above, involves a moving railroad train that represents Jupiter, moving along its track about the Sun. The kid in the propeller beanie throws a tennis ball that represents a spacecraft. It encounters the train, which transfers its momentum into the ball.
It's interesting to note the speeds in the cartoon. The propeller-beanie kid sees his tennis ball moving away from him at 30 miles per hour. So does the Sun, sitting on the stationary platform. The engineer driving the train sees the ball coming at about 80 MPH, since the train is moving 50 MPH with respect to the ground. The train and ball interact at 80 MPH. The ball rebounds from the front of the train at nearly the same 80 MPH, which can be added to the 50 MPH speed of the train, because it acquired it from the train. The result approaches a total of 130 MPH.
https://solarsystem.nasa.gov/basics/primer/
Credit to @A.T. who originally shared the source. Well, and credit to the NASA guys who wrote it of course.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
