What's causing the "spooky action at a distance?"
  • B
  • Thread starter Simple man
In summary, the phenomenon of "spooky action at a distance" is caused by the entanglement of particles, which allows for instantaneous communication and correlation between them regardless of distance. This idea was first proposed by Albert Einstein in his theory of relativity, but it was not until the development of quantum mechanics that it was fully understood and tested through experiments. The concept of entanglement challenges our understanding of space and time, and has potential applications in quantum computing and communication. However, the exact mechanism behind this phenomenon is still not fully understood and continues to be a subject of study in the field of quantum physics.
Simple man
34
TL;DR Summary
"Quantum Entanglement and the transfer of information."
If information can't be transferred faster than light speed, what's going on in quantum entanglement? What's causing the, "spooky action at a distance?"
Nobody knows. We don't even know that anything is actually happening that needs to be caused. Different interpretations of QM tell different stories about this, but there is no generally accepted answer.
And in any event, @Simple man quantum entanglement cannot be used to transmit any useful information
"Thanks phinds, for your reply!"
Thanks, Mr. Donis!
Aside from being entangled artificially, how do particles become entangled naturally? I've been reading the article that you sent me, by Susskind. Thanks, it's very informative! Is Microreversability the same as Quantum Determinism?
There is no spooky interaction at a distance in relativistic local QFT. This is built in by construction, leading to the validity of the linked-cluster theorem. The entanglement of observables of far-distant parts of a quantum system does not enable causal faster-than light interactions (that misconception of some early Copenhagen-flavor interpretations was rightfully criticized by Einstein as "spooky action at a distance") but are long-range correlations between far-distant parts of a quantum system caused by its preparation by (usually some local) process (e.g., the preparation of a polarization-entangled photon pair by parametric down conversion using a BBO) and then waiting until the system has propagated long enough such that you can measure the photons' polarization state far away from their source and far away from each other. There's nothing acting spooky at a distance but just local interactions between the measurement device (polarization filter + photodetector) at each of the places. The observed 100% correlations of completely indetermined observables (i.e., completely unpolarized single photons) is there due to the preparation at the very beginning, and measuring the polarization of A's photon let's A immediately know what B will find (or maybe allready has found) when measuring his photon's polarization (with his polarizer directed in the same direction as A's), but she cannot transmit information to B by some faster-than-light mechanism. Even to check, whether the predicted 100% correlation really describes the findings of the experiment right, A and B have to exchange information about their measurement afterwards, and this they can't do with any faster-than-light signal. So, by construction of QED as a relativistic microcausal QFT there's no violation of causality by any "spooky action at a distance"!
Simple man said:
Thanks, Mr. Donis!
An example of "natural" entanglement would be 2 electrons in the same atomic shell. One is spin up, the other is spin down, but otherwise they are indistinguishable. They are entangled.
Likes vanhees71
Related to What's causing the "spooky action at a distance?"
1. What is "spooky action at a distance"?
"Spooky action at a distance" refers to the phenomenon in quantum mechanics where two particles can affect each other's behavior instantaneously, even if they are separated by large distances.
2. What is causing this "spooky action at a distance"?
The cause of "spooky action at a distance" is still a subject of debate among scientists. Some theories suggest that it is due to hidden variables or non-locality, while others propose the concept of entanglement.
3. How does "spooky action at a distance" violate the principles of classical physics?
"Spooky action at a distance" violates the principle of locality, which states that an object can only be influenced by its immediate surroundings. It also goes against the principle of causality, where an effect must have a cause that precedes it.
4. Is there any evidence for "spooky action at a distance"?
Yes, there have been numerous experiments that have demonstrated the existence of "spooky action at a distance." One of the most famous is the Bell test, which showed that particles can be entangled and affect each other's behavior regardless of distance.
5. How is "spooky action at a distance" being studied and researched?
Scientists are using various methods, such as quantum entanglement experiments and theoretical models, to study and understand the phenomenon of "spooky action at a distance." They are also exploring its potential applications in fields such as quantum computing and communication.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
