What's so unusual about entanglement?
In summary: Bob will also change his observation is not just ##\sin^2\frac{\alpha-\beta}{2}## but instead changes according to ##\cos^2\frac{\alpha-\beta}{2}##. In other words, the act of observation "spins" the particle around its axis - just as if you grabbed it by the axis and turned it! This is called the "spin-flip" or "entanglement-induced rotation" effect.This is called the "spin-flip" or "entanglement-induced rotation" effect.
franklinhu
Why does this whole quantum entanglement thing impress anybody?
When you look at articles in the lay press, they tell you that there is an "instantaneous" communication from one particle to another. But as these posts clearly show, there is no communication involved at all. There is just this "correlation" that when you look at one particle, you know what the other one is. This happens as a process of deduction, not communication. If you have two gloves and you send the left one to Seattle and the right one to Boston, when you open the one in Boston and see it is a right glove, you know instantly that the one in Seattle is the left glove. Why do you know? Because gloves come in pairs left/right. If you have the right, then then the left one is elsewhere. Simple deduction, no instantaneous communication between Seattle and Boston required.
But yet, the popular press keeps on pushing this idea that there is some kind of instantaneous "communication" going on. What is worse is the implication that if we change the state of one particle, it is instantly reflected in the other - so not true. Not even the published papers make this wildly wrong claim. Obviously no communication is possible since you're just looking at the right glove in Boston, you can't turn it into a left glove and have the right glove show up in Seattle. It doesn't work that way.
So given that, why are physicists so impressed with something so obvious and completely useless for any practical purposes?
And why does the press keep on insisting this has something to do with instantaneous communication?
Likes Jim Hasty
This is a misunderstanding of quantum entanglement. The outcome is random and correlated not just for a particular measurement but for all possible measurements one could make. For pure quantum states, this always allows a violation of Bell's inequality which no classical correlation can do.
Entanglement does have useful purposes (though perhaps not practical). You can win some coordination games more often if you have entangled qubits available as a resource. In a classical universe this would imply you were cheating by secretly communicating. But entanglement doesn't allow you to communicate. But classically it would require communication. But quantumly it doesn't enable communication. (But repeat.) That's the paradox.
Also, entanglement DOES have practical applications. The obvious examples is quantum key distribution which is already used commercially and will probably see more widespread use over the next few years. There are plans to roll this out to point-2-point encrypt whole communication networks and it might also be possible to use this for encrypted near-field communication for "tap to pay" type services..
If that were all there was to it - one observer measures spin-up on a given axis, the other must measure spin-down because entangled particles come in up/down pairs just as gloves come left/right pairs - you would be right and entanglement would be no big deal.
But that's not all there is to it.
Consider a pair of entangled spin-1/2 particles; we create the pair and then send one member of the pair to each of two observers (traditionally named Alice and Bob). Suppose they measure the spin along different axes? Quantum mechanics says, and experiment confirms, that if Alice measures spin-up on her axis, then the probability that the Bob will measure spin-up on his axis is ##\sin^2\frac{\alpha-\beta}{2}## where ##\alpha## and ##\beta## are Alice's and Bob's angle settings. You can verify that when they both use the same angle the probability of them both getting the same result is zero, just as with the gloves.
Now if you look at the formula you will notice somethingly profoundly weird about it, something that doesn't happen with the gloves: if Alice changes the angle at which she chooses to measure, it will change the probability of Bob getting a given result even though he hasn't changed anything in his setup. Alice can even change her setup while the two particles are in flight and Bob and Bob's particle are light-years away, with Bob's particle just centimeters away from his detector - and Bob's probabilities will change. That's what makes entanglement interesting.
It is possible to prove (google for "Bell's theorem", and check out the website maintained by our own DrChinese) that if QM is correct Bob's results cannot be determined just from the setting of his detector and the properties the two particles had when they were created. One way or another, you have to include Alice's setting as well.
Likes Borg, Zmunk, eigen and 1 other person
What you can read in the lay press about quantum theory is almost always wrong. Entanglement is, indeed, a feature of the quantum-theoretical world which is most distinct from anything we have in terms of classical physics, which is always local and realistic.
This means that in classical physics you have a one-to-one mapping of physically observable quantities with the mathematical "objects" of the theory, which are fields (the classical electromagnetic field, energy-momentum-stress and angular-momentum tensors of macroscopic matter distributions). The interaction between these objects are always local in the sense that there are no actions at a distance. The physical laws are causal and deterministic in the strict sense. Causality means that there is an arrow of time inherent in the space-time structure and all dynamical physical laws are formulated in the sense of cause-effect relations, e.g., you have a given charge-current distribution, which are the sources of the electromagnetic field, which in turn acts back to the charge-current distribution, and you have a self-consistent set of equations of motion describing this in a cause-effect sense. The interaction is always local in the sense that the force density is determined by a local functional of the electromagnetic field. The theory is also deterministic, which means that if you know the state of the system, i.e., the field configurations exactly in the past you can calculate them for any later time, and the knowledge of this state of the system implies the precise knowledge about any outcome of measurements you can do on this system.
Quantum theory, i.e., relativistic quantum field theory and the Standard Model is different. It is still causal and interactions are local, but it is not deterministic. Already the complete knowledge about the state of the system does not imply that you know the outcome of all measurements. To the contrary, if you prepare a system like an electron such that e.g. its position is pretty precisely known (you can never know it really precisely!) this necessarily implies that its momentum is quite unknown. The only thing you know about this electron, even when you have prepared it, what quantum physicists call a pure state, which is the most precise preparation you an make in principle. This has nothing to do with some technical problem to measure the electron's momentum precisely or to manipulate the electron in a way to determine it precisely; it is just not a property of an electron that it can have a well determined position and momentum at the same time.
The interactions in the standard model are still local by construction, i.e., you build in locality (the technical term is micro-causality) from the very beginning of constructing the maths of the model. This implies that it is impossible within the theory to communicate in any way with signals that propagate faster than the speed of light in a vacuum.
At the same time you can have long-ranged correlations between far distant parts of a system. The most common example are pairs of entangled photons. Photons are quanta of the electromagnetic field, and nowadays the quantum opticians can produce two-photon states that have entangled polarizations by shooting a laser into a certain sort of crystal to create such two photons by absorbing a photon from the laser field and emitting two new photons, each with half of the energy of the laser photon. The total polarization of the two photons is 0 (determined feature of this two-photon state). The polarization of each of the two photons alone is maximally indetermined, i.e., when one observer (usually called Alice) is measuring the polarization of her photon, she gets with 50% probability that it's horizontally and with 50% probability that it is vertically polarized.
This is another feature of quantum theory: Even if you know the precise (pure) state of the two photons as a whole, you may have minimal knowledge about other observables that are not determined by the state, representing the corresponding preparation procedure of the pure two-photon-polarization state. The only thing you know about the polarization of Alice's photon are probabilities, and in this case the single-photon state is represented by the state of minimal knowledge in the sense of information theory.
The same is true for the other photon in the two-photon state. Since the momenta of the two photons are back-to back you may wait long enough by putting two detectors far away from the two-photon source, so that the two photons are registered very far away from each other. As long as the photons do not interact with anything else, they still stay in this pure two-photon state you began with. Both photons (Alice's and the other one detected by Bob) are "unpolarized", i.e., if you measure a lot of single-photon polarizations with identically prepared entangled photon pairs both Alice and Bob find with 50% probability horizontally and with 50% probability vertically polarized photon. There's no way to predict the outcome of these polarizations, and according to quantum theory indeed each of the photons in the pair do not have a determined polarization state at all.
Now you can keep track of which photon measured by A belongs to the photon from the entangled pair measured by B by just very precisely noting the time when A and B register their photons. Then it turns out that whenever A finds a H-polarized photon B necessarily finds a V-polarized photon! Although the single-photon polarizations are maximally undetermined, there's still a 100% correlation between them!
But that's not the most curious property of quantum theory! If Alice and Bob adjust their polarizers in certain relative angles and if they do statistics about some very specific polarization observables they find something which is mathematically proven to be impossible in any local deterministic theory. This is the violation of the famous Bell inequality, which holds for any local deterministic description of the photons. The idea behind this is that it could well be that the photons have some properties we simply don't know, i.e., there are socalled hidden variables that determine each of the photons' polarization, but we simply don't know these, and that's why the polarizations appear to be "random", but only because we don't know the values of the hidden variables. The violation of Bell's inequality rules out, however, any locally realistic description of the photons' polarization. At the same time the very precise measurement of this violation of Bell's inequality matches the predictions of quantum theory with the same precision.
The conclusion is that the world is for sure not describable entirely in terms of local realistic theories. It may be that one day somebody finds a non-local realistic theory, but that's very difficult, because at the same time you must avoid the violation of relativistic causility, i.e., one cannot simply assume that signals are exchanged faster than with the spped of light between the two photons when measured by A and B at a far distance apart without destroying the causality structure of relativistic spacetime. This also implies the assumption of a "collapse of a state", which are (in my opinion unnecessarily) assumed in some interpretations of quantum theory.
Likes goat-on-a-stick
Nothing is useless! Everything can be turned to some purpose or other.
So given that, why are physicists so impressed with something so obvious...
It's not communication. However, when you collapse one member of an entangled system, the remaining member(s) are affected immediately. With an entangled pair, this can be easily demonstrated. No one understands the precise mechanism. But it is not classical (local and realistic).
As to obvious: entanglement was known by 1935. But it was not until 30 years later that Bell figured out the peculiar attributes of entanglement that led to his famous Theorem. That was the watershed moment in understanding the fuller implications of entanglement.
Maybe it's such a big deal because it's the Western common sense to think that the universe is made up from separate things, like objects, quantum systems, etc. We take the everyday illusion of separateness for granted. But that is merely an unproven philosophical assumption, maybe of Greek and of Biblical origin.
An alternative view may for example be that everything is one, meaning that everything is entangled with everything else in this universe (otherwise none of this could be happening anyway). And we can track "immediate" entanglements for a while.
Likes Leef
Well, if there's no collapse, there's nothing to understand about it. For me that's the most simple solution of this "problem", but now we entering metaphysics again, and too much of that is not healthy in physics ;-)).
Just correlation does not violate Bell inequalities. That's the big deal about entanglement violating Bell inequalities.
So you can't scientifically model a situation where Bell inequalities are violated without communication between parties.
But then (loophole free) experimental confirmation of violation of Bell inequalities falsify claim of relativity that nothing can move faster than light.
So you close your eyes and hope that there is some loophole in that chain of reasoning.
The Bell inequality is violated according to standard quantum theory, and this precisely implies that there's no "communication" between the particles necessary to make up the quantum correlation (which is stronger than any correlation that's describable by a local realistic theory) described by entanglement. The correlation is due to the preparation of the entangled state and not due to the measurement (on an ensemble of identically and independently prepared systems!) to reveal this correlation by measurement. What's true is that you need to compare the measurement protocols between the two parties (Alice and Bob) to find out about the correlations, but that has nothing to do with the quantum nature of entanglement. That's just usual "classical" communication between A and B.
If we take clicks in detectors as objective facts of reality then what you say is not true as proved by Bell. Do you agree?
franklinhu said:
Why does this whole quantum entanglement thing impress anybody? [...] So given that, why are physicists so impressed with something so obvious and completely useless for any practical purposes?
An introductory lecture which may be interesting to see: Anton Zeilinger - Quantum Information and Entanglement, which includes descriptions of experiments and applications.
It's worth taking a moment to say exactly what is meant by "communication" here. Whatever it is, it can't be causal, because when the two measurements are spacelike-separated we can interpret the correlation either as Bob's measurement influencing Alice's or as Alice's measurement influencing Bob's.
Likes gjonesy
No, I don't. The clicks are just registering the photons and the outcome is according to quantum theory, violating Bell's inequality in accordance with the predictions of quantum theory. It does not say that there is a faster-than-light signal between the two "click events", of put differently, the correlation in there (objectively!) according to the preparation in an entangled state, long before the clicks but not due to faster-than-light signals between the "click events". A collapse interpretation is not necessary and in my opinion violates basic principles like causality and thus I think one should abandon them from the interpretation of the theory. It's metaphysics anyway and more in the realm of personal belief than scientific facts.
Vanhees, please understand that it does not matter what quantum mechanics says. Loophole free experimental (by clicks in detectors) violation of Bell inequalities plus Bell theorem is all that is required.
You are using symmetries of relativity to analyze a situation that contradicts relativity. It won't work of course.
I don't understand, what you want to say. This does not prove that there's faster-than-light communication between the two photons or the measurement devices. The findings can be explained with standard quantum field theory, and that is by construction microcausal. So there's no necessity to give up Einstein causality, but local realism.
Indeed experiment + theorem proves that faster-than-light communication is the only scientific explanation.
This contradicts Bell theorem so there has to be error in that reasoning.
I have no doubt about Bell theorem being correct.
BAM! That is what I have been looking for, it is by far the best explanation of the WOW factor. I have had a hypothesis for many years about why entanglement does this and so far it has not failed me. At this time I have one question only. Is there any known process / experiment that can create an entangled pair where by they are not created at the same moment? Secondary Entanglement by trading off from an ordinal pair does not count. Put another way for clarity, is it a requirement that entangled particle experiments are initiated with a simultaneously created pair.
Likes Imager
Not sure why you would exclude pairs created via swapping. They are as entangled as anything is entangled.
But when it comes to "ordinary" entangled pairs, there is no particular requirement that they appear as if they were created at the same time. Most of the time, they *don't*appear as if they were exactly simultaneously created. There is usually a small window of variation from pair to pair.
If this is indeed the DrChinese I am deeply honored
I am by no means excluding the end result from pairs created via swapping. I attempted to relay that in my last sentence. I am taking a shot at self validate my hypothesis to at least the limits of my ability and the initiation (step 1) is a key part of that.
Considering instrumentation and uncertainty limitations there will always be some window of not appearing at precisely the same moment. Also if the time spread we are talking is within a few molecules wave length time wise my hypothesis is still looking pretty good.
For now I am remaining tight lipped about my hypothesis for a number of reasons to extensive to explain here. It has been in the making for a life time. To learn just a bit about me I have only one posting on this site that includes a few details. If you like I would welcome you to my FB page. https://www.facebook.com/john.leefers
Oh and by the way if my hypothesis by some miracle turns out to be even 10% correct, faster than light speed communications will be only the tip of an iceberg. I have already built the subspace com in my head and it doesn't look anything like the entanglement experiment I have reviewed.
Thank you for the reply
You may want to step back and take a look at the mathematical definition of an entangled state. (There's a good one at the bottom of page 183 of this book if I got the GoogleBooks link right).
This might be a good time to mention the Physics Forums rule prohibiting posting speculation and personal theories that have not made it through the peer review process. There are a number of threads in the "Forum Feedback" and "Academic Guidance" sections explaining how new theories are developed and why Physics Forums is not part of that process.
Well, it's a bit more complicated than that (i.e. than limitations of measurement). The devices used to time arrival are quite accurate.
Keep in mind that simultaneity is not required from entangled pairs. There are entire papers written about the coincidence time windows due to issues in determining which separate particles (photons) belong to the same pair. Even when you are looking at electron pairs, there are many issues regarding timing.
Keep in mind that there is no specific known physical mechanism for entanglement. It is simply something that is a deduction from quantum theory, at some level. When you ask: "why did that pair end up entangled?" there is no real answer. For entangled photon pairs from PDC, you have something like 1 pair coming out for every 10 million photons going in (that is not an exact ratio, the point is that most input photons are not transformed to entangled pairs). When a pair does come out, it is impossible to trace its past or its exact source where it was created. There are many possibilities, and many will not have the photons created at exactly the same time and place.
-DrC
zonde said:
Indeed experiment + theorem proves that faster-than-light communication is the only scientific explanation.This contradicts Bell theorem so there has to be error in that reasoning.
No! The explanation is standard QED, not faster-than-light communication. The correlations, described by the preparation of the two photons in a polarization-entangled state, are there, because of the preparation procedure, e.g., by parametric down conversion in a birefringent crystal. Although the single-photon polarizations are maximally uncertain (state of maximal entropy, i.e., ##\hat{R}=1/2 \mathbb{1}## for the polarization state of each of the single photons in the pair) the 100% correlations are a fact due to the preparation in the entangled state, e.g., in the singlet state ##|\Psi \rangle=1/\sqrt{2}(|HV \rangle-|VH \rangle)##.
This explanation does not contradict Bell's theorem, because standard QFT is not "local realistic", it's "local quantum".
The press does get a good deal wrong.
The important thing about entanglement TO ME, is how it relates to the uncertainty principle. The uncertainty principle was first taught to me as a measurement problem. EG, once you measure a particles position precisely, the momentum measurement is uncertain. And a great deal of uncertainty follows the rules of measurement. The question that naturally arose was whether the uncertainty is a measurement thing, so the measurement of position rendered momentum UNMEASURABLE, or whether the uncertainty is related to the properties that a thing fundamentally has, so the measurement of position renders the momentum non-existent.
The clever thought (by Einsein, Podalsky, and Rosen, EPR) was to consider two identical particles, and measure the position of one and the momentum of the other.
Entanglement is that experiment. The two things are identical. And once you measure the momentum of particle #1, the particle #2 loses position as a fundamental property. That is why it is impressive. It shows that the uncertainty is fundamentally based on the underlying reality NOT containing a defined thing. Not something we don't know, but something far more weird, that has properties that interact with measurements in a way that is not understandable. A system that does not have fundamental property sets that we don't know, but doesn't have fundamental property sets.
In your example, there is no uncertainty. If measuring a glove pair, you can measure perfectly a left-handedness, and a right-handedness. And knowing the system was never in question. But say that anytime you measured the gloves handedness, you destroyed it and could not measure the color, or if you measured the color, you could not measure the handedness. So you could know "Blue", but not "left-handed", or you could know "right-handed", but not "Green". Now say you could know you have two entangled gloves ... why just destructively measure the color on one, and the handedness on the other. Now you have demonstrated that both properties existed as underlying elements of the glove reality, and uncertainty was based on measurement issues.
The entire fundamental issue is that when you measure the first gloves handedness, the second glove "knows" and loses color along with the first glove. The math seems to prove it (and I say seems, because I have the same reluctance to accept the proof, even though it is absolutely 100% correct).
The information that the entangled particles share is not a valid basis for communication. Somehow the entangled particles operate in a way that ignores they are in separate localities that are fundamentally disconnected. That seems to say they are instantaneously connected. But if they are, then it is in a way that we really can't exploit.
The entanglement experiments ALL agree that if you measure the same property, you get the exact expected results eg, Left in one place Right in the other. The suggestion of the experiments is that once you measure Left in one place, and know Right in the other, you cannot know color. In the glove experiment, if colors can be blue or green, and handedness can be left or right, a blue left, implies a green right as the other. And the odds can be known exactly for any set of measurements at the two locations. There is no uncertainty. What the many experiments with entangled particles keep showing, is that the odds that are exactly expected, are not the odds that are obtained. That answers a fundamental question. The instantaneous communication is speculation.
Likes DrChinese
You mean that QED explains why measurements of entangled particles can violate Bell inequalities?
You have given Hilbert space QM description of entangled state. Hilbert space QM is non-local. So what argument do you want to make by that?
[mentor's note - inappropriate comment deleted]
"If you have two gloves and you send the left one to Seattle and the right one to Boston, when you open the one in Boston and see it is a right glove, you know instantly that the one in Seattle is the left glove."
This is not entanglement. This is an example of classical correlation, with local hidden variables.
If you put each glove in a box, you could write down under the box whether it contains the right or left glove.
Such written informations are the local hidden variables.
The situation is very different for quantum entanglement.
If you put 2 correlated particles in two boxes, you could not beforehand write down on the boxes what the measurements results would be, as the Bell's theorem (Bell's inequalities) clearly prove.
Would it be far fetched to say that the quantum world becomes classical(-like) via entanglement? We always receive inputs via interactions which are known to break entanglement and the world is entangled most of the time.
  • #31
It might be better to say that the quantum world becomes classical because of decoherence. You are right that entanglement is involved - a particle interacts with a macroscopic detector and the two end up in an entangled state (the non factorizable superposition of "particle is in state X and detector reads X" and "particle is in state Y and detector reads Y"). Then decoherence causes this superposition to rapidly evolve into one of the two classical states: We measured X or we measured Y.
(There is a mathematical subtlety about proper versus improper mixed states here... let's not go there right now please?).
  • #32
Some classically unexpected results of quantum theory used to bother me a lot when I was younger. But now that I am in my sixties, my lack of understanding no longer seems so disturbing. I think this is because I no longer imagine that I will ever be able to "logically" explain everything in the world either to myself or to others. In particular, it seems clear that we have no basic understanding of time, either in Special or General Relativity, nor in any part of quantum theory, nor even in Newton's theory of gravitation. Each of these theories seem to violate our expectations about time in one way or another. Since we -- all people, as far as I know -- have as yet no good way to think about the key concept of time, I no longer feel alone in not understanding any particularly surprising results of quantum theory or relativity. I can still be astonished, but I no longer feel defeated by things I cannot understand or explain.
One more point: I have learned about so many utterly amazing things in our world/universe that a few extra inexplicable correlations are nowhere near the most surprising things I know about. As a simple example, it is overwhelmingly astonishing to simply survey the orders of magnitude we can observe in both time and space. Parts of our universe are so much bigger -- and parts so much smaller -- and parts so much slower -- and parts so much faster than we can ever hope to directly perceive! We are tiny and insignificant and probably will never understand very much of what we know exists. And that I find very wonderful.
  • #33
The end result of your implied QFT explanation is based on "clicks in detectors", right? Well these "clicks in detectors" is all the "local realism" it takes for Bell's theorem to be relevant.
  • #34
I wouldn't say that. A typical physics experiment consists of three steps:
  1. Setting up the system in a particular state.
  2. Letting the system evolve in time.
  3. Performing a measurement on the system.
Steps 1 and 3 involve macroscopic objects: Particle sources and particle detectors, and maybe bubble chambers, etc. Step 2 involves microscopic objects: undetected electrons or photons or whatever.
Bell's theorem is about the issue of whether you can explain the statistical observations for Step 3 by assuming definite, but unmeasured, properties for the microscopic objects involved in Step 2. The clicks in detectors are realistic, but take place in Step 3.
  • #35
I totally agree. If there is no way to discern the direction of causality in relativistic sense, then causality is relative, and can't be identified: A does not 'influence' B and neither vice-versa, for it can't be discerned! Correlations are a informational phenomenon, that is to say, only when the necessary information is gathered and investigated, the correlation emerges. Information is not linked to specific matter or energy, until it is measured and determined. It 'is' nowhere in particular. Therefore it can't 'travel' (faster than light) in that sense. I hope I interpreted you right.
