When is the Electric Potential 0
The electric potential is defined relative to a reference point, commonly set to zero at infinity. It is not necessarily zero where the electric field is zero, as potential can remain constant without changing. The potential can also be defined as zero near a smaller charge, depending on the context. Grounding a conductor means it is held at a defined potential of zero. Understanding electric potential requires recognizing that it is a relative measure rather than an absolute one.
Katran0595
The question asks: Where is the electric potential 0?
I believe the relevant equations are v=1/(4*pi*epsilon) (Q/r) or v=-Ed
I think that the electric potential is 0 when the electric field is zero as well. However, I am not quite sure which equations to look at exactly or if an equation is necessary. Some answers state that the electric potential is zero when it is near the smaller charge or it is zero when the point is at infinity.
Welcome to the PF.
Is there a figure that goes along with this question? Can you scan it or describe it? :smile:
Welcome to the PF.
Unfortunately there is no figure. The professor just asked us the general question :(
It is nothing to do with the field's being zero. Where the field is zero, that just means the potential is not changing there, in any direction.
Potential, whether electric or gravitational, is a relative matter. That is why we usually speak of potential difference. You can set any point to be at zero potential, and determine potentials elsewhere in relation to it. In particular, when we say that some conductor is grounded, we just mean that it is held at the potential we are defining as zero.
That said, a usual convention is to say that the potential at infinity is zero.
"Potential energy" is always relative to some given point. You can choose the potential energy to be 0 at any given point by choosing to calculate it relative to that point.
  • · Replies 22 ·
  • · Replies 23 ·
  • · Replies 16 ·
