When will I hear this ball strike the ground?
  • Thread starter Thread starter myoplex11
    Ball Ground
To determine when the sound of a ball striking the ground will be heard after dropping it from a 350m high cliff at 15 degrees Celsius, the time for the ball to fall must be calculated first. The speed of sound in air at this temperature is approximately 340 m/s. The total time includes both the fall time of the ball and the time it takes for the sound to travel back up to the observer. The calculation involves dividing the distance by the respective speeds. The final answer will provide the total time until the sound is heard.
myoplex11
you drop a ball over the edge of a 350m high cliff. If T=15 deg celcius when will hear it strike the ground?
time=distance/speed
do i just divide the 350m by the speed of sound in air at 15 deg celcius?
Hi myoplex11!
Yes, just add that to the time for the ball to fall. :smile:
9K
  • · Replies 18 ·
