Where does the equation C=2*sqrt(km) for Critical Damping come from?
The equation C=2*sqrt(km) for critical damping is derived from the analysis of damped harmonic oscillators, specifically in the context of a ruler cantilever experiment. Critical damping occurs when the damping force is precisely balanced to prevent oscillation, allowing the system to return to equilibrium in the shortest time possible. The discussion highlights the mathematical approach to solving the equation of motion for a damped spring system and the significance of the parameter values in determining the system's behavior. Resources such as college-level physics textbooks provide foundational insights into critical damping and its derivation. Understanding this equation is essential for accurately analyzing damping in mechanical systems.
physics51
what's the background on this equation, I can't find anything about I, what can you guys tell me about it related to damping, when to use it, how to derive it, what it means, etc.? Anything is useful!! Thank you!!
C= 2 sqrt km
Im using this equation to find the damping from a ruler cantilever experiment. Any information about what critical damping really means and how it reflects in a ruler cantilever is also really helpful. Thank you again.
From the context I guess that you are discussing a damped spring pendulum with the equation of motion
$$m \ddot{x}=-C \dot{x} - k x.$$
To solve this equation a nice trick is to make the substitution
$$x(t)=\exp(\lambda t) y(t).$$
Plug this into the equation and check that then ##y## fulfills
$$m \ddot{y}+(C+2 \lambda m) \dot{y} + [k+\lambda(C+\lambda m)]y=0.$$
Now make ##\lambda=-C/(2m)## to get rid of the term with ##\dot{y}##. Then the equation of motion for ##y## simplifies to
$$m\ddot{y} + \left (k-\frac{C^2}{4m} \right) y=0.$$
Now discuss what happens for the different values of the expression in the bracket,
$$k-\frac{C^2}{4m}<0, \quad k-\frac{C^2}{4m}=0, \quad k-\frac{C^2}{4m}>0.$$
For an ODE with constant coefficients I’d just make the ansatz ##x(t) = A \exp(\lambda t)## and solve the characteristic equation, but any way that works works.
Well, then you've the trouble with exactly the case of critical damping ;-).
Where did you look? Most college-level introductory physics textbooks will have a discussion of critical damping and will derive this formula.
