Which of these possibilities will produce emf
  • Thread starter Thread starter songoku
    Emf
The discussion centers on which scenarios produce electromotive force (e.m.f.) in a circular coil. Participants suggest that a circular coil in a non-homogeneous magnetic field or moving in a non-homogeneous field can generate e.m.f. due to changes in magnetic flux. There is confusion regarding the definition of non-homogeneous fields, with some interpreting it as a magnetic field that varies with distance rather than time. The consensus leans towards the idea that a coil at rest in a non-homogeneous field will not induce e.m.f., while movement through a varying field may lead to e.m.f. Overall, understanding the behavior of magnetic fields is crucial for determining e.m.f. production.
songoku
Which one will produce e.m.f?
(i) A circular coil placed in a non-homogenous magnetic field
(ii) A circular coil moved with constant velocity in a homogenous magnetic field
(iii) A circular coil moved with constant velocity in a non-homogenous magnetic field
(iv) None of the above
E=-N\frac{d\phi}{dt}
\phi=BA~\cos \theta
I think the answer can be (i) and (iii) because there is change in B and it will cause the change in magnetic flux. Am I right?
Non-homogeneous field may not change with time. It changes with distance. So by keeping the coil in such field will not produce EMF.
Hi Mr rl.bhat
I don't really understand about the field "changing with distance". Maybe it means, for example, the first 2 m the field is 2 T, then for the next 5 m the field is 10 T?
songoku said:
Hi Mr rl.bhat
According to me, the diverging or converging magnetic field can be treated as non-homogeneous field.
Hi Mr. rl.bhat
Now I don't understand the term "converging and diverging magnetic field"...:frown:
hi Mr. rl.bhat
I have another opinion. Since the field changes with distance (although I don't know what this means) and the distance changes with time, it implies that the field changes with time. Therefore, e.m.f will be produced ?
If you consider field due to current carrying solenoid, depending on the direction of the current, the magnetic field from one end is diverging and on the other end it is converging.
If you keep a coil at rest any where near the solenoid, emf will not be induced.
I don't know what is interpretation of homogeneous and non homogeneous field.
  • · Replies 35 ·
