- #36
- 14,245
- 6,728
Wikipedia didn't explain it well. Can you make an exact quote of Bell?A. Neumaier said:Not according to Bell (who coined the term) or Wikipedia (whose article is based on Bell's definition).
I am currently trusting that wikipedia quoted Bell correctly. If you think it is a misrepresentation you should provide the evidence.Demystifier said:Wikipedia didn't explain it well. Can you make an exact quote of Bell?
A. Neumaier said:Nothing of what you list is essential in the context of this thread. You misinterpreted this context: Neither Alice nor Bob nor Bell were mentioned in the OP, which defined the context.
Here is an exact quote of Bell (the bolding is mine):A. Neumaier said:I am currently trusting that wikipedia quoted Bell correctly. If you think it is a misrepresentation you should provide the evidence.
Demystifier said:Here is an exact quote of Bell (the bolding is mine):
"An essential element in the reasoning here is that a and b are free
variables. One can envisage then theories in which there just are no free
variables for the polarizer angles to be coupled to. In such ‘superdeter-
ministic’ theories the apparent free will of experimenters, and any other
apparent randomness, would be illusory. Perhaps such a theory could be
both locally causal and in agreement with quantum mechanical predic-
tions. However I do not expect to see a serious theory of this kind. I
would expect a serious theory to permit ‘deterministic chaos’ or
‘pseudorandomness’, for complicated subsystems (e.g. computers)
which would provide variables sufficiently free for the purpose at hand.
But I do not have a theorem about that."
Who then has the authority to define the meaning of the word, if you reject the meaning given to it by Bell, by Wikipedia, and by the originator of the thread?DrChinese said:I disagree, Arnold. Superdeterminism is NOT determinism, regardless of the words Bell did (or did not) use and regardless of the Wiki article.
Where is the logic? I argue on pure logical grounds (the only grounds where things are indisputable). You and Bell have only plausibility arguments.DrChinese said:Superdeterminism is ONLY intended as an "out" for Bell's Theorem. I do not take seriously the idea that Bell considered it as an out, he was just pointing out (in a very roundabout fashion) how desperate you would have to be to reject the logic
The question of local realism is completely irrelevant from my point of view. Nobody expects it to hold, not even the defenders of loopholes.DrChinese said:and hold onto local realism.
Have you read the exact quote of Bell I have given?A. Neumaier said:if you reject the meaning given to it by Bell
Why do you think that defenders of loopholes do not expect local realism to hold?A. Neumaier said:The question of local realism is completely irrelevant from my point of view. Nobody expects it to hold, not even the defenders of loopholes.
Can you please enlighten me in which way deterministic chaos would provide variables sufficiently free for the purpose at hand?Demystifier said:I
It is just a subjective feeling. Maybe because I am just defending the loophole without caring about the theorem.Demystifier said:Why do you think that defenders of loopholes do not expect local realism to hold?
I still do not doubt that the Wikipedia quote of Bell on which I relied is as exact as yours. Unlike Wikipedia you haven't even given a source.Demystifier said:Have you read the exact quote of Bell I have given?
A. Neumaier said:Who then has the authority to define the meaning of the word, if you reject the meaning given to it by Bell, ...
Deterministic chaos creates an illusion of freedom. Since one cannot measure or control the fine differences between almost identical initial conditions, it looks as if different outcomes emerge from identical initial conditions. You still have not learned the FAPP way of thinking necessary to understand Bell.A. Neumaier said:Can you please enlighten me in which way deterministic chaos would provide variables sufficiently free for the purpose at hand?
Even deterministic chaos leaves no freedom for any system to choose a different setting than the one determined by the initial conditions, and hence known to Nature long before the experiment begins.
And if I did, would it change your conclusions?A. Neumaier said:Unlike Wikipedia you haven't even given a source.
A. Neumaier said:Maybe because I am just defending the loophole without caring about the theorem.
In [1] (listed below), Bell clearly specifies his assumptions in response to critique of his original formulation (italics are his):Demystifier said:Can you make an exact quote of Bell?
In a deterministic universe, this assumption is obviously violated. For it means that these values are independent of the values of all observables prior to the moment the settings are made. Indeed, if they would depend on the latter, fixing one of the values provides a nontrivial relation on the prior variables in their past light cone and hence provides information about the latter. Thus they give information about what was before, in direct contradiction to Bell's assumptions.J.S. Bell said:'It has been assumed that the settings of instruments are in some sense free variables ...' For me this means that the values of such variables have implications only in their future light cones. They are in no sense a record of, and do not give information about what has gone before.
Because I like to distinguish between clear logic and wishful thinking.DrChinese said:But I have no idea why you would pick this position to defend, given your usual attention to key points in Physics.
A. Neumaier said:... the logic of Bell's argument requires a nondeterministic universe.
A. Neumaier said:Because I like to distinguish between clear logic and wishful thinking.
True. But this has nothing to do with the present thread, which is, according to the OP, neither about local realism nor about which things can be proved with or without superdeterminism.DrChinese said:With GHZ, for example, a single example will produce results in contradiction to local realism.
I claimed that ''the logic of Bell's argument requires a nondeterministic universe'', and this is true for the argument under discussion, viewed on purely logical grounds.DrChinese said:It most certainly does not, and none of your reference implies as much.
A. Neumaier said:1. True.
2. But this has nothing to do with the present thread, which is, according to the OP, neither about local realism nor about which things can be proved with or without superdeterminism.
A. Neumaier said:In a deterministic universe, this assumption is obviously violated. For it means that these values are independent of the values of all observables prior to the moment the settings are made.
stevendaryl said:I feel like I'm arguing a two-front war here. On the one hand, I don't think that it's impossible to have a superdeterministic explanation for QM statistics. On the other hand, I think that such a theory would be very bizarre, and nothing like any theory we've seen so far.
Oops! I had missed this. Superdeterminism in the form proposed by demystifier in post #4 indeed allows anything because in a deterministic and reversible dynamics one can start at the wanted result and work backwards. So it allows also very irrelevant possibilites.DrChinese said:allows the formulation of a local realistic quantum theory."
This is already illusory in a deterministic universe. Thus Bell argues for a nondeterministic universe.Demystifier said:In such ‘superdeterministic’ theories the apparent free will of experimenters, and any other
No. Only unknown to us. There is a big difference between undetermined and unknown.stevendaryl said:In a deterministic universe, it's still the case that the initial state of the universe is undetermined.
A. Neumaier said:No. Only unknown to us. There is a big difference between undetermined and unknown.
A. Neumaier said:Oops! I had missed this.
A. Neumaier said:This is already illusory in a deterministic universe. Thus Bell argues for a nondeterministic universe.
DrChinese said:Further, this entire line of reasoning is moot anyway as there are other (non-Bell) tests in which there is no statistical component and/or there is no observer choice. With GHZ, for example, a single example will produce results in contradiction to local realism. Superdeterminism does NOT rescue that.
No. it is enough to know that Alice and Bob have no choice at all to make all arguments logically invalid. Plausibility is a different matter, but what is plausible is always arbitrarily arguable.stevendaryl said:the parts of the universe relevant to Alice's and Bob's future choices have to be known at the time the twin pair was produced.
Not knowing what the choice is is still quite different from being able to make an arbitrary choice.stevendaryl said:No, it doesn't need to be nondeterministic, but there must be enough freedom in the initial conditions that knowing only part of the universe gives you no information about the rest of the universe.
A. Neumaier said:No. it is enough to know that Alice and Bob have no choice at all to make all arguments logically invalid.
stevendaryl said:Now, THAT's a good point. I'll have to think about it.
