Why Capacitors in Parallels vs. Series: Coaxial Capacitor Case
The discussion centers on the configuration of two capacitors—one filled with vacuum and the other with a dielectric material—within a coaxial setup. Initial calculations suggested a series arrangement, but the resulting capacitance equation did not align with expected outcomes, particularly when one capacitor's length was set to zero. Upon recalculating, the parallel configuration yielded results that matched expectations, confirming that both capacitors share the same potential difference. The reasoning is that since each metal tube is an equipotential, this leads to a parallel combination rather than a series one. The conclusion emphasizes the importance of understanding potential differences in capacitor configurations.
PhysicsRock
A cylindrical capacitor is made off of two coaxial metal tubes. Here, ##r_1## refers to the outer radius of the inner tube and ##r_2## the inner radius of the outer tube. Both metal pieces have a length of ##l##. Between the two pipes, a glass tube is inserted from one side, a distance ##a## (##0 \leq a \leq l##) into the capacitor (filling the gap entirely). It's relative permittivity is ##\varepsilon_r > 1##. Calculate the capacitance of the contraption as a function of ##a##.
Capacitance of a cylindrial capacitor ##\displaystyle C = \frac{2 \pi \varepsilon_0 L}{\displaystyle \ln\left( \frac{r_2}{r_1} \right)}##.
So my idea was to separate the capacitor into two individual ones, one of length ##l - a## filled with a vacuum and one of length ##a## filled with the glass tube. The capacitances then are
C_0 = \frac{2 \pi \varepsilon_0 (l-a)}{\displaystyle \ln\left( \frac{r_2}{r_1} \right)}
for the vacuum capacitor, and
C_1 = \frac{2 \pi \varepsilon_0 \varepsilon_r a}{\displaystyle \ln\left( \frac{r_2}{r_1} \right)}
for the capacitor with the dielectric. Originally, I thought they must be in series, however, doing the math, the overall capacitance for that case would be
C = \frac{2 \pi \varepsilon_0 \varepsilon_r (l-a) a}{l + a (\varepsilon_r - 1)} \frac{1}{\displaystyle \ln\left( \frac{r_2}{r_1} \right)}.
This, however, doesn't make any sense. For example, when plugging in ##a = 0##, what one would expect is that the capacitance is equal to that of one cylindrical capacitor of length ##l## filled entirely with a vacuum. According to the above expression though, it would be zero.
So I tried calculating the capacitance for them being in parallel and I get
C = \frac{2 \pi \varepsilon_0}{\displaystyle \ln\left( \frac{r_2}{r_1} \right)} [ l + a (\varepsilon_r - 1) ]
which does satisfy all expectations, for example for the scenario discussed above. This leads to the conclusion that the capacitors must in fact be placed in parallel. However, I don't understand why, since typically for such problems the separated capacitors are always in series. Can any of you explain to me why this is the case here?
Thank you.
Each of the metal tubes is an equipotential. This means that the potential difference across the vacuum capacitor is the same as the potential difference across the glass capacitor. Two capacitors that have the same potential difference across them form a parallel combination.
Thank you. That makes total sense.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
