Why Do Capacitors in Parallel Share the Same Voltage?
  • Thread starter Thread starter oneplusone
    Voltage
Capacitors in parallel share the same voltage due to their direct connection via a conductor, which allows current to flow until equilibrium is reached. When capacitor C1, charged to 20.0 V, is connected to uncharged capacitor C2, the voltage across both capacitors becomes equal. The relationship Q1/C1 = Q2/C2 holds true because the voltage across both capacitors must be the same when they are connected. Current flows until the voltage across the resistive elements in the circuit stabilizes, confirming that the final voltages are equal. Understanding this principle is essential for solving related capacitor problems effectively.
oneplusone
C1 = 6.00 uF
C2 = 3.00 uF
##\Delta V = 20.0## V
Capacitor c1 is first charged by the closing of s_1. Switch S_1 is then opened and the carved capacitor is connected to the uncharged capacitor b the closing of S_2. Calculate the initial charge acquired by C_1 and the final charge on each capacitor.
C=Q/V
See attached.
I get everything in this solution besides when they set Q_1/C_1 = Q_2/C_2.
Is it ALWAYS true that the voltage across two points are the same?
If you connected 2 capacitors, remember that their plates are connected by a conductor.
Now what happens when you connect two points with a conductor?
Current is formed, so there is a voltage?
And since there is no loss of electrons (charge) and the intensity (current) is the same, the voltage is the same?
Is that correct?
Well, as long as there is current flowing, you can't really make a problem out of it, at least not here, because it's not in a steady state.
But yes, when current does stop flowing in the circuit, the voltages are the same on both capacitors.
Now, there are formulae for the final charge/voltage in such an arrangement. I'd suggest you go through your textbook or look through the forums. I've forgotten the formulae myself, but I do remember that they exist.
Is that correct?
You could include the resistance of the wire as a resistor in your crcuit, making it 3 elements. Current will flow through the resistor until the voltage across the resistor falls to zero. At the start, there are different voltages on each side.
oneplusone said:
C1 = 6.00 uF
C2 = 3.00 uF
C=Q/V
See attached.
When S2 is closed the two capacitors are in parallel so by definition their voltage drops must be the same.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
