sophiecentaur
- 30,131
- 7,398
I think you are referring to instantaneous voltages (?). On the graphs you attached, you don't actually plot any 'back emf'. You are inferring it from the current on the graph. But, in the same way that the current that you plot is not in phase with the plotted input volts, why should you assume that the back emf is in phase with the (plotted) current which is causing it?
The concept of back emf is only a way of describing behaviour - like the reactive force when you push against a wall. From what you have written, you seem to be assigning it more importance - as if it's "really there" and that, somehow, it violates something.
My point about needing a series source resistor to do a proper analysis is that you could measure (/calculate) the voltage across the series resistor (which will, of course be less than the supply voltage) then this back emf you are after is the difference (vectorial / phasor) between the supply volts and the volts across the resistor.
Try relating all this to the bahaviours of RL and RC filters and to the high pass/low pass functions. If there is no resistance involved then there is a flat frequency response because the voltage source 'insists' on a whatever voltage it is producing.
that I'm not sure what we're talking about
