- #36
rbj
- 2,227
- 10
mdeng said:I am not sure I follow you.
i guess you don't.
Why is the burden on me to show/justify this when I am merely asking why light travels at a constant c (in vacuum) to anyone and everyone?
it's because of the fact that the laws of physics, both qualitatively and quantitatively are the same for observers that are both inertial that c is the same for both observers. otherwise, you have two observers that are in the same situation, an inertial frame of reference, and they both perform the same experiment and get measurably different results. if [itex]c = 1/\sqrt{\epsilon_0 \mu_0}[/itex] was measurably different, then at least one observer either gets a different law of physics, at least quantitatively with a different c or [itex]\epsilon_0[/itex] or [itex]\mu_0[/itex]. you have to tell us why in the world would two observers, in equivalent situations - that is inertial frames of reference, just not the same inertial frame of reference - two observers with equal claim to being the stationary observer, so there is no good reason for those Maxwell's equations to be inaccurate for either one of these observers.
unless you supply us with the good reason. if your "good" reason is that c is different for one observer over the other, that isn't good enough. that's the circular reasoning. it continues to beg the question for why should the laws of physics be different for one inertial observer than the other.
so, yes. the onus continues to be to come up with a reason for why the laws of physics are different for these two observers. if you cannot, the inescapable consequence is that the laws of physics are the same. if the laws of physics are the same, the parameters in those laws are the same. one of those parameters is c.
You seem to be equating my question about constancy of light to about why one should prefer one inertia frame over another when observing light. Well, I don't think the two questions are the same, even though they may be related or even equivalent to some extent.
they are to any extent unless you can tell us why one observer gets one set of laws and the other gets another set.
SR itself does *not* prove there must exist constancy c. On the contrary, it assumes so and is built on top of it. And without this assumption, I am not sure how SR could claim what you stated above.
i only said how, two or three times.
Maxwell's equation may have predicted this (or simply happens to agree with it),
in Maxwell's equations related to magnetism, Ampere's Law and the Biot-Savart Law.
[tex]\oint_C \mathbf{B} \cdot \mathrm{d}\mathbf{l} = \mu_0 \iint_S \mathbf{J} \cdot \mathrm{d}\mathbf{S} = \mu_0 \iint_S \rho \mathbf{v} \cdot \mathrm{d}\mathbf{S}[/tex]
[tex]d\mathbf{B} = \frac{\mu_0}{4\pi} \frac{(\mathbf{J}\, dV) \times \mathbf{\hat r}}{r^2} = \frac{\mu_0}{4\pi} \frac{(\rho \mathbf{v}\, dV) \times \mathbf{\hat r}}{r^2}[/tex]
[tex]\mathbf{F} = q \cdot(\mathbf{E} + \mathbf{v} \times \mathbf{B})[/tex]
so, with just Maxwell's equations, what value do you use for [itex]\mathbf{v}[/itex] for either the moving charge that is the magnetic source or the moving charge that the [itex]\mathbf{B}[/itex] field is acting on? if i am moving relative to you, do you use the values of velocity that you measure or the values that i measure? why should it be the values that you measure? why are your measures of velocity, that you plug into Maxwell's equations to compare the theoretical result to experiement, be the perferred values over the velocities that i measure in my frame of reference? you have to justify that, and if you can't, it necessarily follows that the parameters used in the expression of physlcal law be the same for you as they are for me.
but it's not explain why light must behave this way. IMO, constancy c must be the entailment of something beyond SR, not something proven by SR.
I don't have any answer as to what this "something" is, nor why or why not we'd prefer one inertia frame over the other,
then, for you to be logically consistent, if you have no reason why one inertial frame is preferred over the other, you have no reason to expect that the theoretical nor measured speed of propagation is experienced differently for the two intertial frames of reference.
other than "that is what SR (together with its assumption) says".
it's an ancillary assumption or a corrollary of the main postulate that all inertial frames of reference have equal claim to being "stationary". if either can say that they are stationary when they do experiments, they should get, as it appears to themselves, the same results within an experimental error (assuming they are equally "good" experiments - that their level of experimental error are equally low).
I am not saying SR is wrong, and in that sense I agree with you that we should not prefer so and so. But I'd like to ask what dictates light to behave this way?
and i said precisely why, given the main postulate of relativity: that it is all relative, not absolute (at least as far as how we experience velocity - acceleration is a quantity that we have an absolute measure of, at least until GR). but i don't think that GR says a word about gravitons, does it? i thought that was an extension of the ideas of quantum mechanics to gravity, in a similar sense of how photons are related to the electromagnetic action.
