Why does the propagation constant in the Helmholtz equation include j?
  • Thread starter Thread starter baby_1
The discussion centers on the presence of the imaginary unit "j" in the propagation constant γ of the Helmholtz equation. It highlights confusion regarding the equation γ = j √(ω²μ(1 - jσ/ω)), where the factor of j appears to be a mistake. Participants clarify that the correct representation should reflect a negative sign for the propagation constant. The conversation emphasizes the importance of understanding the mathematical representation of electromagnetic wave propagation. Overall, the inclusion of j is linked to the complex nature of wave behavior in lossy media.
baby_1
This is my own question: Why do we intentionally include the imaginary unit jj in the propagation constant after taking its square root?
Helmholtz equation
Here is my question:
\nabla^2 \bar{E} + \omega^2 \mu \left( 1 - j \frac{\sigma}{\omega} \right) \bar{E} = 0
where
\gamma = \alpha + j \beta
\gamma^2 = \omega^2 \mu \left( 1 - j \frac{\sigma}{\omega} \right)
\gamma = j \sqrt{ \omega^2 \mu \left( 1 - j \frac{\sigma}{\omega} \right) }
why is there a factor of j in the expression for γ?
Yes, the ##j## outside the square root in the second equation above looks like a mistake. If you square this equation, you do not get the first equation.
Where did you see the second equation?
Dear TSny,
Thank you for your help.
In many electromagnetics resources, I have noticed that the propagation constant is often represented with a "j," but I am having trouble understanding why this is the case. I have attached one of the references for your review.
I realized my mistake: in the main equation, the sign of the propagation constant should be negative. Thank you once again for your help!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
