Why is perforated cathode used in the discovery of anode rays?
Perforated cathodes are utilized in the study of anode rays to allow electrons or protons to pass through, facilitating the absorption process. The holes in the electrodes enable the passage of these rays, which ionize the surrounding gas. This ionization results in the formation of positive gas ions that subsequently move towards the cathode. The design of perforated cathodes is essential for observing the behavior of anode rays in experiments. Understanding this mechanism is crucial for advancements in particle physics and related fields.
Iqraasgherali
Why is perforated cathode used in the discovery of anode rays? Is there a hole in anode through which cathode rays pass and what causes the glow behind cathode and anode electrode? Is this glow due to the rays?
There are no equations.
I really tried to solve it a lot and the info that I gathered is :
Electrons or protons can be ABSORBED by cathode or anode so there must be some hole in the electrode for the rays to pass.
These electrons ionize the gas and those positive gas ions move towards cathode.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
