Why is the value of EMF generated by a generator not zero at t = 0 s?
At t = 0 s, the coil is indeed rotating, which means that even though it hasn't completed a rotation, it is in motion. This movement generates an electromotive force (emf) due to the principles of Faraday's Law, which states that emf is induced by changes in magnetic flux. The discussion clarifies that emf is related to the coil's motion rather than its static position. Therefore, the value of emf is not zero at t = 0 s. Understanding this concept is crucial for grasping the dynamics of electromagnetic induction.
songoku
This is not homework.
Let say coil of generator is in horizontal position (i.e. the direction of magnetic field of the magnet is perpendicular to the normal vector of the plane of the coil). The coil is then rotated so emf will be induced on the coil.
If I draw the graph of Φ (magnetic flux) against time, the shape will be like sin wave and if I draw the graph of emf against time, the graph will be like negative cosine wave so it means that the starting point of graph of emf against time will a certain negative value (let say -5 V).
ε = - N . dΦ / dt
Does this mean that initially there will be emf induced on the coil at t = 0 s?
Initially, at t = 0 s, the coil has not been rotated yet so based on Faraday's Law, there won't be any change in magnetic flux so why the value of emf is not zero at t = 0 s?
Thanks
No, but it is rotating. The emf is created by movement, not position.
Likes Delta2 and songoku
Thank you very much haruspex
A Full Stack Development Program prepares students to create end to end web applications using front end as well as back-end technologies. The purpose is to get experience in creating user interfaces, managing databases, and conducting server-side activities, resulting in a thorough understanding of how web platforms work. This skill is essential since it allows developers to participate at every step of a project, enhancing critical thinking and productivity. registering in Full Stack...
