MikeGomez
- 343
- 16
Yes, but it really needs to be said that way so that people who read it don't think that there are different kinds of gravity..Ibix said:I think the distinction being made is between non-inertial frames in flat spacetime (e.g. rotating sections on spacecraft to provide "artificial gravity") which can be handled in special relativity, and curved spacetime which cannot.
The term "fake gravity" makes my head explode, and I think it should be banished from the face of the earth.Ibix said:Whether you regard non-inertial effects in flat spacetime as "fake gravity" is up to you..
The thing is, I think even "artificial" gravity, although not as bad, should not be used. Inertia and gravity are phenomenon identical in nature. Maybe "induced" gravity would be a good way to describe space-station gravity.
PeterDonis wrote up an excellent description of the situation from another post here recently.
PeterDonis said:...There is a common confusion here which is worth going into. When we speak of "tidal forces", or for that matter when we speak of a "fictitious" force such as centrifugal force or the force of gravity, we are really being sloppy. Consider the following three cases:
(1) A person standing at rest on the surface of the Earth.
(2) A person pressed against the wall of a rotating cylindrical chamber (like those amusement park rides where you stand against the wall, the chamber starts rotating, and then the floor drops out from under your feet but you stay pressed to the wall and don't fall).
(3) An extended object free-falling radially towards Earth and being stretched by tidal gravity, setting up stresses (i.e., internal forces) inside the object.
In all three of these cases, there are forces present, but they are not, according to GR, properly described as "the force of gravity", "centrifugal force", or "tidal force". They are, respectively:
(1) The force of the Earth's surface pushing up on the person's feet, keeping them from following a geodesic path (which would be free fall towards the center of the Earth).
(2) The force of the chamber wall pushing on the person's back, keeping them from following a geodesic path (which, if we imagine the chamber far out in deep space, so there is no large gravitating mass present, would be to fly off in a straight line tangent to the chamber wall).
(3) The force of the internal bonds in the material that makes up the object, keeping its parts from following geodesic paths (which would be for the parts of the object to diverge from each other).
In that thread PeterDonis has accepted the statement that "all three cases are different manifestations of the same underlying phenomenon".
