Wind Turbine DIY Project for School - Steel Plate vs Non Magnetic Plate
Building a wind turbine for a school project involves using coils and magnets, typically mounted on a non-magnetic board with magnets on a steel plate. Steel plates can enhance the generator's power by concentrating the magnetic field, which may lead to improved efficiency. While some suggest using non-magnetic plates for the magnets, the consensus leans towards steel due to its ability to confine magnetic field lines effectively. Additionally, steel is a strong and cost-effective material for this application. Ultimately, using a steel plate is likely beneficial for increasing the turbine's power output.
dinablaster
i don't know if i am in right part of forum.
i want to build some sort of wind turbine for a school project. all the diy project are 6 or 9 coils with 8 or 12 magnets. the coils are on non magnetic board and the magnets on steel plate.
why on steel, the steel plate increase the total power of generator, like concentrate the magnetic field? is not better to mount the magnets on non magnetic plate to?
I could see using smaller magnets and compensating by using steel plates to act as additional magnets. Not really sure though. Got a link to a DIY one?
this is an example. http://www.windenergy.nl/website/files/artikelen/AXIAL_FLUX_HowItWorks.pdf .
my q is if seel plate increase or no the power of the turbine
From the article it says the magnetic field lines are confined by the steel hub the magnets are attached to. This might be the reason. That and steel is strong and relatively cheap.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Someone who shows interest in science is initially a welcome development. So are fresh ideas from unexpected quarters. In contrast, there is a scientific community that is meticulously organized down to the last detail, allowing little to no external influence. With the invention of social media and other sites on the internet competing for content, unprecedented opportunities have opened up for...
I am following someone on Youtube who has built a rocket shaped (4 proprllers) drone for the world speed record ... He was having problems with internal heat from electical control gear and battery inside the sealed rocket (about 1kw waste heat) Speed is 500km/hr , I suggested a 4mm hole in the tip of the nose and 8mm hole at rear which should alow sufficient air cooling .. I said this will increase thrust because the air exiting is hotter .. a bit similar to a ram jet ... was I correct...
