Work done by gas expanding into a cylinder+piston system
The discussion centers on the work done by gas in two scenarios: quasi-static expansion against atmospheric pressure and rapid expansion with no heat exchange. In scenario A, the work is calculated using a constant pressure approximation, leading to a straightforward formula. In scenario B, the work is derived from a more complex relationship involving the gas's pressure and volume changes, suggesting a faster, potentially explosive expansion. The participants debate whether the work done in both scenarios can be considered the same despite differing paths in PV space. Ultimately, the conclusion is that while the endpoints may be identical, the nature of the expansion affects the work done.
LCSphysicist
A thin-walled metal container of volume V contains a gas at high pressure.
Connected to the container is a capillary tube and stopcock. When the stopcock is
opened slightly, the gas leaks slowly into a cylinder equipped with a nonleaking,
frictionless piston, where the pressure remains constant at the atmospheric value $P_0$.
(a) Show that, after as much gas as possible has leaked out, an amount of work $P_0(V_0-V)$
has been done, where $V_0$ is the volume of the gas at atmospheric pressure and
temperature.
(b) How much work would be done if the gas leaked directly into the atmosphere?
I will summarize briefly my reasoning for both letters, since the answer is immediately after that:
A) The work is quasi-static, and the pressure is approximatelly constant and equal to the atmospheric pressure, so the works is $$W = -p\int dV = -p_{0} (V_{0}-V)$$
B) The work is fast, fast enough that no heat flows thought the gas, so that the work is $$W = -\int p dV = -\int_{V_i}^{V_f} p_i (V_i)^{\gamma} dV /V^{\gamma}$$ $$ P_i V_i^{\gamma} / P_o = V_f ^{\gamma}$$
What do you think? I am almost sure it is wrong, so i am posting here to get any help on letter b
If your system is the gas, why do you feel that the answer to B is different from A?
As i said, because the first one "leaks slowly", and nothing has been said about the second one, so i suppose it is more "explosive".
I have questioned myself also if the work is the same, but i was not able to argue why it should be. Even so the final points on (PV space) is the same, the path could be different, resulting in different work.
The question implies that the gas is still leaking slowly in case B, but into the atmosphere instead of into a cylinder and piston.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
