Work done by power supply to maintain a constant current
The discussion revolves around the relationship between work done by a power supply and changes in potential energy in a system where a coil flips in a magnetic field. It questions whether the equation should include a negative sign, suggesting that the work done by the power supply should counteract the increase in potential energy. The original answer guide omits the negative sign, leading to confusion about the correct formulation. Participants emphasize the importance of maintaining constant current and the implications of potential energy changes. Clarification is sought on whether the negative sign is necessary to accurately represent the work-energy relationship in this context.
mymodded
A coil with N turns and area A, carrying a constant current, i, flips in an external magnetic field, ##\overrightarrow{B_{ext}}##, so that its dipole moment switches from opposition to the field to alignment with the field. During this process, induction produces a potential difference that tends to reduce the current in the coil. Calculate the work done by the coil's power supply to maintain the constant current.
$$U = NiAB\sin(\Theta)$$
Since we want the current to stay constant, the change in potential energy that's caused by the coil flipping in the magnetic field should be "undone" by the work done by the power supply, so shouldn't ##W = -\Delta U## ? the answer guide did it without the negative sign, so I'm wondering if the negative sign should be included or not and because we don't really want to add more potential energy.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
