Work done in elevator problem — is it positive or negative?
The discussion centers on calculating the work done by gravity on an elevator and its passengers as they move between floors. The user calculated the forces involved and arrived at a total work of 2891 kJ but was confused about the sign of the answer. It was clarified that the problem specifically asks for the work done by gravity, which is negative when the elevator moves upward against gravitational force. Misinterpretation of the question's wording contributed to the confusion, highlighting the importance of precise language in physics problems. Understanding that gravity does negative work in this context is crucial for accurately solving such problems.
pandatime
A lift of mass 800kg carries 20 people from a hotel lobby to their floors. Half the people get out on the 10th floor, the remainder on the 15th. What is total work done, in kJ, by gravity moving the lift and passengers? (You should assume each passenger has a mass of 70kg, the lobby is floor 0 and each floor is 10m in height)
W = Fd
w = mg
Hi! So, I've actually already solved this problem.. for the most part.
I have split up the work into two sections, floor 0 to 10, and floor 10 to 15.
From floor 0 to 10, I did
## F_{elevator} = w_{pass.} + w_{elev.} ##
## F = (70)(20 (num. of pass.))(9.8) + (800)(9.8) ##
## F_{elev.} = 21560N ##
From floor 10 to 15, I do the same calculations ( but change the number of passengers) and get ## 14700N ##
If I add both of these numbers, I get a total of 2891 kJ of work done, which is the correct answer ish.
What I'm getting wrong is the sign of the answer. I was under the impression that the work done would be positive since the elevator is moving up, and the force done by the elevator to move everybody and the lift up is also pointing upwards right? I'm struggling to grasp why the answer would be negative instead?
You are asked for the work done by gravity, not by the elevator motor.
Things do not in general fall upwards.
The problem is asking "What is total work done, in kJ, by gravity moving the lift and passengers?" Although it is clear who is doing the work on whom, the phrasing "... by gravity moving the lift and passengers" can be easily misconstrued by the unwary to imply that gravity is responsible for the motion and therefore the displacement and the force are in the same direction. Perhaps it would have been clearer to ask, "What is the total work done by gravity on the elevator and its contents as they are moved from the lobby to the 15th floor?"
To @pandatime : If the question were asked as I suggest above, would it have made a difference to your answer? I am just curious.
Likes jbriggs444 and pandatime
Thank you both of you! It's actually the first time I've done one of these problems, I usually deal with other scenarios and so I think I got tripped up by the fact that they asked for work done by gravity instead of just like an applied force that a person does in most of the other questions, I do think if it was worded your way @kuruman I might have been able to catch it by myself so!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
