Work done on a gas as volume decreases
The discussion focuses on calculating the work done on a gas as its volume decreases from infinity to zero, using the pressure function P=e-v2. The work is expressed as dW = PdV, leading to the integral W=∫0∞e-v2dV. The solution references the Gaussian integral, concluding that W=(√∏)/2. Participants seek confirmation on the correctness of this calculation. The conversation emphasizes the application of mathematical principles in physics to derive the work done on the gas.
kabailey
In a mathematical model, a gas is under a pressure of the form P=e-v2 (v is volume). Find the work (in Joules) done on the gas as its volume decreases from infinity to zero.
dW = PdV
Solution Attempt:
W=∫0e-v2dV
http://en.wikipedia.org/wiki/Gaussian_integral
Gaussian Integral=∫-∞e-x2dx=√∏
∴∫0e-v2dV
=(√∏)/2|0
W=(√∏)/2
Is this correct?
anybody?
