Work Done on A Proton in an Electric Field
The equation for work done on a proton in an electric field is given as W = -qEd, resulting in a calculation of -2.76 x 10^-18 J. The confusion arises regarding why the work is reported as positive, despite the proton moving in the direction of the electric field. The key point is that the work done by the electric field is considered positive, as it indicates energy supplied to the proton. The negative sign in the equation reflects the work done against the field when considering the proton's charge. Ultimately, the positive value represents the energy gained by the proton from the electric field.
physicslady123
Calculate the work done in moving a proton 0.75 m in the same direction as the electric field
with a strength of 23 N/C
W=-qEd
W=-qEd
=-(1.6*10^-19)(23)(0.75)
= -2.76*10^-18 J
However, the answer is 2.76*10^-18 J. Why is the word done positive and not negative? Since it's traveling in the same direction as the electric field, shouldn't it be negative work?
It seems to me the result quotes the work done by the field
Likes physicslady123
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
