Wrong sign in my answer, why? SR + Addition of velocity....
The discussion revolves around the confusion regarding the sign in the relativistic velocity transformation equations. The original poster derived a result with a minus sign, while the expected answer contains a plus sign, leading to questions about the assumptions made regarding the direction of velocities. Participants emphasize the importance of clearly showing work to identify mistakes in the calculations. The conversation highlights the need to clarify whether the velocities are considered in the same or opposite directions, as this affects the outcome. Ultimately, the resolution hinges on correctly applying the principles of special relativity and ensuring consistent assumptions about the direction of motion.
LCSphysicist
Adopt the speed of light equals one.
Calls ##cos = c##, ##sin = s##
$$ux' = \frac{v-uc}{1-uvc}$$
$$uy' = \frac{us}{\gamma(1-uvc)}$$
$$tan \theta' = uy' / ux' = \frac{us}{\gamma(v-uc)}$$
So that's basically my solution. The problem is: The answer is ##\frac{us}{\gamma(v+uc)}##. Now, i can't understand why there is a plus sign instead my minus sign. Seems that, to got the answer provided, it was assumed that, for example, ##ux' = \frac{v+uc}{1+uvc}##. Certainly wrong, since if v = uc, ux' should be zero.
So my question is, maybe my answer is right, the problem is that i assumed v to the right and the author assumed v to the left? Or did i a mistake? WHere?
Please show your work, not just the final result. It is impossible to help you and tell you where you have gone wrong if you do not provide this.
Hello. The work is already showed, i am not sure what do you mean. I am just using the transformation of velocities in SR. Assuming that the velocity of particle u is $$\vec{u} = u cos (\theta) \hat{i} + u sin (\theta) \hat{j}$$ and $$\vec{v} = v \hat{i}$$
I would say both are wrong. If ##\theta = 0## we have:$$u' = \frac{u - v}{1 - uv}$$
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
