Yes! Calculating Friction Coefficient
The calculations for the friction coefficient involve determining the force of gravity (Fg), net force (Fnet), and the forces acting on the object (Fax and Fay). The final friction coefficient is calculated as 10 divided by the normal force (Fn), which is derived from the gravitational force minus the vertical component of the applied force. There are concerns about the accuracy of the significant figures used in the calculations, suggesting they should be rounded to three. Additionally, clarification is needed regarding the expression "Fax = Fax leftward - Fax rightward." Overall, the calculations appear correct with some minor adjustments needed for precision.
extDependency
A 30kg object is being pulled across a horizontal surface. The acceleration is 1.2 m/s2. The object is being pulled by a handle that is at 25 degrees. Friction force is 10 N. What forces can we find?
Fg = m * g
Fnet = m * a
Fa = Fax / cos(angle)
Fay = Fa * sin(angle)
Fg = m * g:
Fg = 30 * 9.8 = 294 N
Fnet = m * a:
Fnet = 30 * 1.2 = 36 N
Fax = Fnet + Ff:
Fax = 36 + 10 = 46
Fa = Fax / cos(angle):
Fa = 46 / cos(25) = 50.75
Fay = Fa * sin(angle):
Fay = 50.76 * sin(25) = 21.45
Fn = Fg - Fay:
Fn = 294 - 21.45 = 272.55
Ff = mu kinetic * Fn, solving for coefficient:
Coefficient of friction = 10 / 272.55 = .035Does this look correct?
Making assumptions about how you are defining your variables, it all looks ok, except "Fax = Fax leftward - Fax rightward". What did you mean by that?
Your answers show too many significant figures, given the precision of the provided numbers. Round to at most three.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
