YOU: Fix the US Energy Crisis
  • Thread starter russ_watters
  • Tags
    Energy
In summary: Phase 3, 50 years, decision-making, maintenance, and possible expansion. -Continue implimenting the solutions from Phase 2, with the goal of reaching net-zero emissions. This would be a huge undertaking and would cost hundreds of billions of dollars. -Maintain the current infrastructure (roads, buildings, factories) and find ways to make them more energy efficient. -Explore the possibility of expanding the frontier of science and technology, looking into things like artificial intelligence, nanotechnology, and genetic engineering. This could lead to new and even more amazing discoveries, but it would also cost a fortune.
  • #106
IQ and the trees of Africa
Astronuc said:
it is much less expensive to plant trees than to erect a reinforced concrete wall three feet think.
Trees are dangerous and destroy property. Like other live pets, they require constant supervision and frequent health check-ups. The property damage and the health maintenance of trees are expenses that might make the total ownership costs of concrete walls seem inexpensive in comparison.
I had an oak tree that was growing at a phenomenal rate of about 1 foot/yr.
The average American http://yosemite.epa.gov/oar%5Cglobalwarming.nsf/content/EmissionsInternationalInventory.html . Was your oak tree putting on 20 tons of dry weight per year?
multiplied by 2E9 trees over an area of 72,000 sq miles, that could handle perhaps anywhere from 10 million to 100 million tons of CO2/yr
And, meanwhile, America http://yosemite.epa.gov/oar%5Cglobalwarming.nsf/content/EmissionsInternationalInventory.html . One reason ocean seeding is being explored is that trees are notoriously pathetic at soaking up atmospheric carbon.
[edit: Keep that filth out of my forum, hitssquad. I won't tolerate it. -Russ]
  • #107
Regarding trees, I was actually thinking about areas outside of those with high population density. I have flown over the country numerous times, and there seems to be a lot of open areas that could be reforested.
they [tree] require constant supervision and frequent health check-ups.
Most trees that I see appear to have no human intervention at all. Some trees certainly do become diseased and that is why property owners need to inspect trees, as much as they need to be aware of the condition of the house.
Most of my trees are at a distance from my house that exceeds the height. I have one maple tree that did drop one of is side trunks just behind the house, so I watch is more carefully - it will probably be removed soon. I also had a large spruce tree removed because it overwhelmed the neighbor's driveway.
But it seems high winds or stormy weather is the culprit. If trees were not around, the storm winds would directly affect the house, and high winds can do significant damage to a house.
If one was going to the expense of a 3-foot (1 meter) thick concrete wall, then it would be worthwhile to build the exterior wall structure of the house in this manner. Then surround the house with trees to shade it and provide a wind break. We have a lot of birds around our property, and it is very nice to listen to them and watch them.
Sitting by the window looking out, I thought today, that it would not be much of a view staring at a concrete wall. BTW, a concrete wall would get quite hot in the summer. Metropolitan areas are usually 4-5°C (so-called urban or metropolitan heat island effect).
Based on the stats that you provided, certainly trees are not the total solution, only part of it. Clearly energy conservation is a necessary part. Reduction of fossil fuel (coal and oil) is necessary. Part of that should be a significant improvement in vehicular mileage.
hittsquad - Thanks for the links on ocean seeding. I will definitely look into that. But is it practical (even if feasible) to put 5.5 billion tons of CO2 into the oceans each year? Is that something in which you are involved?
I just started researching "carbon sequestration" area, so I am still learning about it.
  • #108
Energy News Update
Energy efforts close to starting
State program will help fund solar, wind farm projects
By JOHN G. EDWARDS
REVIEW-JOURNAL
Two developers said Friday they are getting closer to beginning construction on separate alternate energy projects that will take advantage of a new state program.
Developers of Solargenix Energy, a planned 50-megawatt solar thermal project in the Eldorado Valley, and Ely Wind, a proposed 50-megawatt wind farm in Northern Nevada, have applied for approval under a new state program that makes it easier for them to get financing.
Solargenix hopes to obtain financing by March and start construction of the solar thermal plant, said Gary Bailey, a local executive with the company. The facility will use troughs that reflect sunlight and heat on to a fluid-filled pipe that will spin a turbine to generate power. [continued with more information and listed projects]
http://www.reviewjournal.com/lvrj_home/2004/Nov-27-Sat-2004/business/25354555.html
  • #109
Here is another very interesting new technology. If it works out as planned, if will produce oil from almost all sorts of wastes containing hydrocarbons, like sewage, plastics or paper. And at the same time also reduce the amount of waste that needs to be stored and also degrading many dangerous substances.
http://en.wikipedia.org/wiki/Thermal_depolymerization
  • #110
I offer a fowl solution
Turkey droppings fuel power plant
NEW YORK (Reuters) -- Turkey leftovers will take on a whole new use after a Minnesota company finishes construction of a power plant fired by the birds' droppings. [continued]
http://www.cnn.com/2004/TECH/science/12/16/energy.environment.turkeys.reut/index.html
  • #111
  • #112
... The fuel cost the Tabbs' $4.02 per gallon, but the business will be able to take advantage of a federal tax credit beginning Jan. 1.
The tax credit may not necessarily make the fuel cheaper than petroleum-based diesel, according to National Biodiesel Board communications director Jenna Higgins.
"We do know it will do a lot to close the gap," she said. The tax credit was included in job-creation legislation signed into law in October.
Higgins could not offer how prevalent Biodiesel had become nationwide, but cited statistics by the U.S. Department of Energy that indicate the alternative fuel was among the fastest growing.
"We estimate that 31 percent of soybean farmers use biodiesel and that number continues to go up," Higgins sad.
"Enthusiasm for biodiesel fuel is contagious," [continued]
http://www.journal-news.net/news/story/1218202004_new01_fuel_121804_n.asp
  • #113
Nuclear-blast resistant homes, and the trees that bravely protect them
If a house cannot withstand predictable wind speeds, it might seem there is something wrong with the design of, or the construction technique used in the building of, the house:
http://www.garylukens.com/steel_frame_homes.htm
  • More structurally stable and stronger than wood framed homes and safer in high winds and other natural disasters.
    The steel framed wall panel used in our construction is the strongest design engineered. This design withstands racking of the structure in winds of excess of 150 mph.
Agreed. A concrete dome capping a concrete-lined subterranian space might be just the ticket for blast protection in case of nuclear attack.
The proposed house is made out of thick, steel-reinforced concrete.
Computer monitors can be used for viewing. Audio speakers can be used for listening. Birds and trees can be computer-simulated, or live video cameras feeding back to the house can be set up where there are live birds and trees. If you would like to add a babbling brook to the scene, it is merely a few keystrokes or mouse-clicks away.
Perhaps it would not be hot on the inside. This concrete is pretty thick. It might be like living inside a cave (except this cave has as many windows as you are willing to add video monitors.)
solution... Clearly energy conservation is a necessary part.
It would seem that qualification and quantification might be needed in order to be able to reach conclusions.
Again, adequate qualification and quantification seems to be lacking.
  • #114
I just built a house with a full dug out basement lined with 12 inch cinder block. I estimate that the basement if 1000 square feet added $100,000 to the cost of the house. I don't think too many folks have an extra $100,000 to waste. Economically it was a mistake. But it is a fine engineering test bed.
  • #115
Is saving money by building wood houses really saving money
Economics in action, Charles:
http://www.aero-data.com/anaglyphs/hurricane_damage_fixed.jpg
How much is a blown-down house worth? How much is a house with a car embedded in its livingroom worth?
http://www.google.com/search?q=car+livingroom+crash
The average American male makes 2.5 million year-2000 dollars in his lifetime and wastes much of that on luxuries such as cars that can go three times the maximum speed limit, low-brow entertainment, jewelry, dysfunctional clothing, mountains of poisonous "food", glorified 18th-century "health care", preventable "accidents", low-brow weddings, divorces from spouses that simple psychological tests would have told them they should not have married, low-brow funerals, etc. On a $2.5 million lifetime income, I think a person can cut back on a few of those things and afford to build a $500,000 high-security home.
And if it's dug into the ground, you can save a little on energy costs, too. An underground house is passively geothermal.
http://www.kettler.com/geot.html
The Heat Beneath Your Feet
Geothermal energy, the heat beneath your feet, is the most stable renewable energy source. Three feet below most of the eartth's surface, the ground temperature is always at least a mild 50 degrees F., and this temperature increases with depth to several hundred degrees.
  • #116
I think that you might find it interesting that steel framed and concrete structures, when built serially (not one-off) and by well qualified personnel, are generally more economical than the general 'stick-built' wood framed houses. The materials for steel or masonry houses generally cost more, but the labor costs are generally considerably lower. Cutting, recutting, measuring, force-fitting, etc. are greatly reduced, for example. Cost of construction isn't the big problem. That problem is:
Tradition! - - - Tradition!
More in general, a certain very influential segment of the American populace wants nothing other than a home that buys into the perceived American (sometimes European) tradition of what a proper house should be. That segment, in particular is heavily represented in the lower middle-class WASP female populace. (This has been borne-out in studies in the past.) This preference is basically a way of buying into this perceived tradition. Convince this very large group that the 'stick-built' house isn't preferable and you can quickly and at no extra cost, start to improve America's energy consumption picture. Fail to convince this group, and we muddle on.
  • #117
Actually, we can save a lot this way. The average temperature a few feet below ground surface, in most climates, averages near sixty degrees year-round. (This is what makes underground homes so attractive to some people.) Masonry houses (brick, block and especially concrete), however also have other properties that make them attractive in this situation (and a few problems). The main advantages, other than structural strength, are those of thermal 'flywheel' and thermal 'wick'. It is well known that masonry tends to hold onto temperature values much better than most building materials. What is less well known is a little discovery made a few years ago by a builder in the US Southwest, that by anchoring a masonry foundation well into the ground, and then insulating this masonry structure on the 'outside', temperatures on the inside can be easily and economically stabilized and maintained year-round. (And, the house itself doesn't have to be underground.)
The drawback to this is the fact that, because masonry is generally cooler than the hot outside air (in summer); when this outside air comes in contact, it tends to dump a lot of its absorbed moisture onto the colder masonry walls. As result, basements are often wet and moldy, especially in the more humid areas.
KM
Likes supersheen
  • #118
There's no reason to assume that concrete will be hotter in Summer than other materials. Actually, it tends to be cooler in Summer and warmer in Winter (thermal, Flywheeling - very similar to water, and the wicking effect). This is why basement walls tend to be cool (and thus damp) in the Summer.
KM
  • #119
[QUOTE+Astronuc] The Sahel and Sahara areas have much larger areas that could be reforested. Assuming that increases rainfall those areas, then crops would be more successfully grown. [/QUOTE]
It must be borne in mind that the Sahara, at least, was once somewhere between fairly lush, and a savannah area (I believe, as recently as about seven or eight thousand years ago). If so, then before trying to change it from what it is Today, we must ask, "what changed it to this state?" If the cause was in nature, then just maybe we can determine and implement what will be required to restore it, and maybe not. If we find out what is required, maybe it will be economically and politically feasible, and maybe not. The frightening thought, though is - - "What if we caused it in some way?". I suspect that the cause was natural but we could have been the culprit, and if so, we'll probably never be able to bring ourselves to correct it (even if we can). We apparently did cause the heavily forested areas of Lebanon to vanish, and we don't have the faintest idea what we must do to correct the situation there. In like manner, much of Michigan was once heavily forested, and we destroyed most of that. (Will that some day become a desert?) We definitely seem to know how to destroy forests, but not necessarily how to rebuild them (especially the old growth types). Now we are working to destroy the rainforests of the Equatorial regions and this will probably influence the world's rainfall patterns in catastrophic ways. (The reason that this isn't raising great alarms around the world, may possibly be the fact that it isn't predominantly the evil Americans that are doing it, but who rather stand to suffer the consequences if it continues, especially in the Western Pacific. Destruction of the South American rain forests will have similar effects on Europe.)
I, personally have little faith in our will or abilities to create forests. I just hope that we don't destroy more of them.
[QUOTE+Astronuc] Regarding trees, I was actually thinking about areas outside of those with high population density. I have flown over the country numerous times, and there seems to be a lot of open areas that could be reforested.[/QUOTE]
Good luck!
[QUOTE+Astronuc] If one was going to the expense of a 3-foot (1 meter) thick concrete wall, then it would be worthwhile to build the exterior wall structure of the house in this manner. Then surround the house with trees to shade it and provide a wind break. We have a lot of birds around our property, and it is very nice to listen to them and watch them.[/QUOTE]
One added suggestion here. Where possible, plant evergreens (softwoods) to the North and West. This will help to block out the winds and snow in the Winter. On the other hand, put the deciduous trees (hardwoods) to the South. In this way you can help to block out direct sunlight in the Summer, while allowing it to come through in Winter.
KM
  • #120
Late to the party here but a few points:
(1) There are multiple energy markets that are currently only tangentially linked.
(2) There are muliple environmental, cost, supply and safety concerns.
Supply
Let's look at the supply issue first. There is no doubt that the supply of fossil fuels is finite. There is no doubt that demand for fossil fuels is poised to increase rapidly as nations like China industrialize. There is no doubt that a limited supply and an inceased demand will increase fossil fuel energy prices in the long run. Technology is going to make more fossil fuels available as prices increase making more expensive to exploit resources more attractive, but the long term trend is still fossil fuel prices going up.
You can argue over whether it will take ten years, twenty years, forty years or eighty years to get there, but an economy that relies on fossil fuels is unsustainable in the long term.
There is also not serious dispute about the fact that the most scarce of the fossil fuels is petroleum, and that the second most scarce of the fossil fuels in natural gas (in both cases relative to current use), while coal, and the non-renewable non-fossil fuel of uranium, are less scarce than natural gas given current useage patterns.
It should also be obvious that our oil supply is highly subject to geopolitical risk. Choosing to exploit oil fields in Alaska may put off the day of reckoning a few years, but the key point is that most of the reserves of oil in the world lie outside the United States in places like the Middle East, Nigeria and Venezula which are not politically stable. (Lots of the world's uranium resources are also located in regions where political stability is lacking).
Multiple Markets
The transporation fuel market, which relies almost exclusively upon petroleum products as an energy source right now, is almost entirely separate from the other demands on our energy supply (i.e. electricity, industrial use, residential and commercial use).
The Non-Transportation Market
The fact that a variety of fuels can be used in the non-transporation market has let to price competition and lots of options to address that part of the energy market. Electricity can be produced using current technology with hydroelectric power, wind power, solar power, coal, natural gas, petroleum, biofuels and waste products, geothermal power, etc.
Petroleum is the least used fuel for heating buildings like homes and businesses in the nation. Industrial users are actively trying to reduce their petroleum use due to environmental and cost concerns. Very little electricity is produced with petroleum and much of that is in isolated areas like Hawaii and rural Alaska where there is no cheap way to transport coal or natural gas and there are insufficient local hydroelectric resources.
Natural gas is primarily used for water heating and heating buildings. It is a versatile fuel which can be used in modified vehicles for transporation, which can be used to generate peak demand electricity (it is expensive as a base electricity fuel), and can be used in industrial use. But, leaving oil for natural gas puts pressure on the natural gas supply (and those of you who heat your homes with gas know that those prices do from time to time go through the roof). Natural gas is the least polluting fossil fuel and can be clean and efficient even in small scale applications (like a home water heater).
There are rooms for significant conservation measures in the non-transportation sector. Better insulated houses and more efficient water heating systems can greatly reduce demand for energy in those areas and the market is likely to make this happen as prices for natural gas (or the main alternative electricity) rise.
There is really no danger of "running out" of energy for the non-transporation section in the near term. Even we knew for a fact that all natural gas supplies would be gone in ten years (and no one is claiming that they will be), electricity could replace every major use of natural gas with no technological advances and fairly modest infrastructure costs as almost all buildings are already wired for electricity. Natural gas is preferred over electricity simply because it is less expensive (outside uses like cooking and artificial fireplaces with are a tiny fraction of the total natural gas consumption of the nation and would still persist even if natural gas prices went up ten fold or a hundred fold).
In the non-transportation sector, thus, environmental, cost and safety concerns are predominant. The main environmental issue in the non-transportation section is that coal fired electricity plants cause significant air pollution and that the mining (mostly strip mining) to burning process for coal also generates significant solid waste and has significant environmental impacts.
Basically, then, anything that is more environmentally attractive than coal is a good idea if it can be done at a manageable cost and with greater or equal safety. Nuclear fission meets this test (particularly with breeder reactors). Wind power meets this test. Photovoltaic power is close to meeting this test for summer daytime peak useage in the sunbelt (i.e. to power air conditioning). Hydroelectric power meets this test but has already been heavily exploited, and geothermal power availability is highly localized. Conservation schemes also abound. Better insultation is the most basic, and solar power is quite efficient at reducing the need to heat water with other fuels (water heating and not photovoltaic applications are the main current commercial use of solar power now). Co-generation plants that use heat directly as well as generating electricity for steam plants in urban or industrial areas are highly efficient. This list is not exhaustive.
In short, the non-transportation section is not in a crisis, and has numerous possible solutions that modest policy nudges to encourage could easily put on a fast track. A simple "carbon tax" on fossil fuel emissions, for example, could easily create the incentive to encourage change while funding research into conservation and alternative sources without unduly tinkering with market mechanisms in this sector.
The Transportation Market
The real problem is in the transportation area. The options for reducing pollution are fewer (and the pollution from this type of energy use is significant), the likelihood of supply being a problem is greater (not actually running out, but seeing prices rise, particularly as China and other developing nations increase their demand while supplies don't get dramatically greater), and the amount of effort needed to adapt to new technologies is greater.
Air
Air transportation will simply have to get more expensive. There is no good alternative for powering a jet to petroleum products, this is a very small part of the total demand (probably under 1%), and this is the highest value petroleum use in the transportation section.
Of course, as air transportation gets mor expensive, passenger rail becomes more attractive for medium distance, budget conscious passengers, indirectly reducing demand in this section.
Rail
One of the best ways energy use in the transportation sector can be reduced is with increased use of rail. Freight rail already is fully converted to diesel-electric hybrid power systems of the type just beggining to appear in passenger cars like the Prius. They are many times less polluting and more fuel efficient and less costly than moving freight by truck with no new technology at all. Shifting more long haul freight to rail, with trucks making deliveries locally, to and from the train station, could dramatically reduce transportation sourced air pollution and petroleum demands.
It does require a new business model and technology, with a focus on containerizing cargo. It would also benefit from modest efforts to increase the speed of freight rail -- not to the 190 mph of the TGV in France for passenger rail, but another 5-10 mph above current norms. Mostly though, it would require much more efficient technology to move containers carried by rail off trains and onto trucks (and visa versa). But, this is a far easier task than creating a hydrogen economy, developing viable fusion power, or a host of other far more commonly discussed sexier energy conservation proposals. Simply removing the government subsidies that favor road over rail (users bear only about 40% of the cost of the road system through gas and other transportatio related taxes, with the rest coming from general revenue taxes mostly at the state and local level) and penalizing trucks that fail to meet the same emissions standards of other parts of the energy use economy would go a long way towards securing this switch.
We also need to look more intelligently at passenger rail to see where it makes sense and where it does not. Passenger rail at an average of about 35 mph over vast rural areas of the interior United States, which is mostly what Amtrack does outside the Northeast Corridor, is idiotic and exists only due to massive per passenger government subsidies. This is better terminated to allow intercity buses (which still beat cars in environmental and safety respects) become more economically viable.
But, passenger rail at 90-190 mph at medium intercity distances (i.e. before the speed advantages of air travel become overwhelming) in high density corridors between urbanized areas (e.g. the California coast, the Northeast Corridor, the Front Range of Colorado, the major cities of Texas, the major cities of Ohio) can make lots of sense. Also, because high speed rail systems are typically in urban areas close to power plants and operate on fixed routes, electricity is often a good energy source for them so the burden on the petroleum supply can be alleviated and shifted to the less crisis prone non-transportation energy sector. The rest of the developed world (Western Europe and Japan) makes wide use of high speed rail in these conditions.
As long as we don't try to use passenger rail to connect small towns in Nebraska, as we do now, it can be a good part of the solution.
Roads
In the near term future, hybrid drives are the best way to reduce petroleum consumption for cars and trucks. They work well at scales from subcompacts to big rigs (keep in mind that our nation's train system already has used this technology for decades, and it has also been tested in Hummer's and SUVs, as well as the more familiar Toyota Prius). It has all the performance of a conventional vehicle, is less polluting, is more fuel efficient, requires no new infrastructure and has a modest price differential which is partially simply a function of economies of scale.
A near complete conversion to hybrid technology could reduce petroleum consmption by 20-30%.
The easiest way to boost hybrid drive technology would be to shift funding for the road system from general taxes to gasoline taxes, which might incease gas prices by 50 cents to $1 a gallon, which creates an incentive of something on the order of $250 per mile per gallon of fuel efficiency improvement, enough to make hybrid drive technology look good.
Along with hybrid drive technology, we also need to look at ways to make diesel engines cleaner burning (e.g. by removing sulfur so we can use more emissions cleaning technology at the tailpipe) so that this more fuel efficient fuel source can leverage the benefits associated with hybrid drive.
A hybrid drive diesel is even more fuel efficient than a hybrid drive gasoline engine, but produces more of certain kinds of pollutants due to a dearth of regulation of those pollution sources so far. Modest emissions regulations for diesel could make this a real good option for reducing petroleum dependency.
In the longer term, we need to think about reducing the sprawl that makes universal use of cars and trucks to do anything necessary, through better land use, and we need to look at wider use of fully electric cars.
Fully electric cars are already viable for intra-city use. They also perform just like a regular car. But, they have shorter range and take a long time to recharge (even though a plug in your garage or at your workplace parking spot is all that is required). This makes them unattractive for anyone who every makes long range trips, as most people buy vehicles for peak use (hence the trend of single individuals driving to work in huge SUVs).
The peak use purchase syndrome for both SUVs and as a discouraging trend for electric cars can be addressed by making the rental car market work better and reducing subsidies and regulatory biases in favor of big, polluting vehicles. Why own an SUV or full cab pickup you only use the full abilities of, when it is quick and easy to rent one for the weekened, at a fraction of the price. A little nudge and attitude adjustment here could have a big impact. For example, why not sell smaller cars and sedans bundled with a voucher for ten days of year of SUV or pickup rentals?
The technological barrier for fully electric cars is batteries. The rest of the technology is proven, works great, and explains why hybrid cars provide an advantage even now. But, batteries are expensive, have lots of toxic elements, and don't have a high enough energy density, among other problems.
R&D efforts towards better batteries should be one of the biggest priorites in the nation, far ahead of nuclear fusion (which even if discovered would only solve a crisis we don't have), other other long shot efforts. It doesn't take a scientific revolution. Improvements of degree make electric cars and trucks more and more attractive. And, once you have viable electric cars and trucks (even if you need petroleum for rural areas, just as we use it in those areas for electricity generation now) that can get widespread use in urban areas, we have largely solved the problems associated with petroleum and can address the source energy pollution problem with the variety of non-transportation section options discussed above.
Likes supersheen
  • #121
I have observed this phenomenon for two years in my new house and it is strange here. In summer moisture is absorbed by the cinder block basement walls. I suspect it goes into the pores so that the basement is not quite as damp as expected. In the fall as the outside cools the water comes out and lands on the windows, lots of it. Then as the basement cools the vapor pressure drops and the windows are dry again.
It is important to have air conditioning or dehumidifier in the basement during some very damp summers.
  • #122
In the news...
...Shortly after the completion of the Nagano plant, Pacific Biodiesel began to attack an even larger problem for the Landfill – grease trap waste. With the addition of a custom designed grease trap oil processor, PacBio was then able to supply its own boiler fuel, again while diverting 140 tons of grease trap oil from the Landfill each month. This biofuel product is available for considerably less than petroleum diesel fuel. [continued]
http://www.biodiesel.com/aboutPacBio.htm
Willie Nelson: On the Road Again with Biodiesel
http://www.biodiesel.org/resources/pressreleases/gen/20040629_Willie_Nelson.pdf
  • #123
So we're going to eliminate fast cars, entertainment involving depictions of car chases, bling, pretty stuff, junk food, health care, weddings, divorces, funerals, and accidents. And, while we're at it, we are going to join a monestary and swear oaths of chastity and obediance, so we can spend all day praying that we going get sick or hurt or die or fall in love or fall out of love or have any emotions that involve the limbic system.
  • #124
while hydrogen is cool, i like this:
Develop nuclear fusion to the point where it is safe and efficent.
Then, develop new battery technology that can recharge quickly and store lots of power.
With nuclear fusion, power everything. No dangerous by-products like smog or radioactive crap.
Then put these batteries in cars and other vehicles and use them to power them. your fueling station will have a plug :bugeye: .
What do you think, it seems logical, dosn't it. THere is probably some problems somewhere, but those can be fixed.
Just an idea that would probably never happen
Fibonacci
  • #125
Fibonacci
Read the whole thread... :smile:
  • #126
Cellulosic oil technology, developed in the UK, but stifled by the Crown\, is our best resource. Next best is "Turkey" fuel, recently developed in US looks to be 2nd best. Things are looking up on the energy front!
  • #127
Robust said:
Cellulosic oil technology, developed in the UK, but stifled by the Crown, is our best resource. Next best is "Turkey" fuel, recently developed in US looks to be 2nd best. Things are looking up on the energy front!
The ethanol is a small step but not really a solution. And by the Turkey fuel I assume you mean the TDP (thermo depolyermization) where different organic wastes can be converted to oil like products. Again, nice step to reduce oil needs but not a full-blown energy solution and not much help on the pollution front.
The electrical system is the big problem and here in the US its mostly coal with some natural gas so the pollution is huge as well. In addition the infrastrucure is old and costly updates have been postponed to the point of massive costs (postponing them even more) so its a very complicated problem.
After reading up on the issues the strongest canidate is nuclear power. IMO the nuclear proponents need an intelligent PR person who can frankly address the needs of the industrialized nations. One who can address the concerns and admit the over-stated promises of the past and fears about the future. A person who can communicate the problems and overall long-term risks and benefits. Until then, we're clawing at incremental improvements.
  • #128
I disagree that the electrical system is the big problem. The electrical system is an opportunity to use cleaner fuels, but, unlike the transportation system, isn't facing any impending fuel shortage and has a host of technical fixes from wind to nuclear available.
In contrast, the continued viability of the transportation system, which overwhelmingly relies upon oil derivatives, is acute. One economic indicator, the price of a barrel of oil (at $58 last time I checked), which has a clear long term trend towards going up, has the potential to paralyze our modern economies everywhere, and particularly in the United States which has chosen not to tax gas nearly as much as its competitors in Europe and Japan (where taxes roughly double the cost of gasoline compared to the United States), and thus is much reliant upon cheap gas than its competitors.
  • #129
in the news:
After a year-long delay, Honda and a partner have announced they will sell a $2,000 home fueling station for natural gas cars starting in the spring of 2005. Initial sales, estimated at 500 a year, will be limited to California, but Honda could then expand to other states such as New York, where natural gas cars are used in the state fleet.
...The biggest obstacle to broader acceptance of natural gas vehicles is the limited availability of refueling stations," American Honda Vice President Tom Elliott, said in a statement. [continued]
http://www.msnbc.msn.com/id/5960905
  • #130
Here's a start, at least. I am thinking the small town of Chico, CA, where I live, could become energy-independent with this tree, while also reclaiming vast areas of hard pan which surround the town.
http://www.livejournal.com/users/foolfaerie420/46528.html#cutid1
In the past year, info on the Internet about the Karanji has doubled, leading me to believe there is already a growing interest. Of course, when I say doubled, you must understand there was not much to begin with.
  • #131
This is a project by statkraft in norway to extract power when freshwater mixes with saltwater.
I read a little about it in a swedish science magasine but I have troubble finding more info on this technology. Does anyone here know anything about it and how big can it become? Obviously there is no shortage of either salt nor freshwater in most parts of the world so if its a efficient energy producer it could very well compete.
Saline power plant trials
In collaboration with SINTEF, NTNU and the Research Council of Norway, Statkraft has just opened the world’s first laboratory dedicated to research on saline power generation.
In Sunndalsfjorden fresh water from the Aura Power Station runs into the fjord. The source of energy is actually the meeting of fresh and salt water.
The technology is based on osmosis, one of the basic principles of physics. All energy levels tend to equilibrate. This means that fresh water has a natural tendency to dilute seawater. We can extract useful energy from the mixing of fresh water and seawater, if they were previously separated by a semi-permeable membrane.
When the fresh water diffuses through the membrane it creates a pressure differential that can be used to drive a turbine. SINTEF is working on the development of this membrane.
Scroll down to middle of page
http://www.ntnu.no/gemini/2003-06e/4-7.htm#19
  • #132
I did not realize how old this thread was before making my post. So I apologise if I should not have brought it back to life.
  • #133
i read the article , but can not figure how they are going to get power from osmosis..
below , this was also on the same page
Problematic aurora borealis
The aurora borealis is a beautiful natural phenomenon, but it can also cause real problems for military high frequency (HF) communication systems in northern Norway. The aurora causes distortions in the ionosphere some 300 km up, where radio waves are reflected back to the ground. These disruptions may interfere with the reception of pictures, text, and sound.
anyone see anything wrong with the statements above..??
for one thing the aurora is an effect of solar wind interacting with the magnetic poles of the planet , its not the cause of anything..
  • #134
One approach is to "dam" a fjord or estuary with an osmotic membrane set at the base of the dam. Fresh water passes through the membrane, dropping the fresh water level by whatever distance is desired for conventional hydroelectric power generation methods. Problems to be solved are: 1) membrane strength to withstand couple hundred kPa to MPa pressure differences between the two sides of the "dam;" 2) membrane permeability to pass sufficient amounts of fresh water to make such a project practical; 3) mixing the diluted seawater on the seaward side of the membrane to maintain enough osmotic gradient to maintain flow; 4) filtration ahead of the membrane to reduce fouling; 5) determining bypass flow rates to rinse crud the filtration system passes from the upstream side of the membrane.
If it ain't obvious, the trick being accomplished with the membrane is to add 10s to 100s of meters of fall to the stream, river, whatever at its outlet to be used for h-elec power generation.
  • #135
Dose anyone know what the max output of a large hydro generator at full capacity
  • #136
There is no theoretical limit, but the largest in existence is the Three Gorges Dam at 18,000 megawatts, 18 times a typical nuclear reactor.
  • #137
Great discussion. I did not read all the posts, but my comments would be: source of hydrogen must be considered. I've heard that most hydrogen comes from natural gas and we're back to fossil fuels again. I think ethanol has great potential if a feedstock like switchgrass can be utilized. Even with corn, this country has a huge agricultural capacity, if it can be grown with less environmental impact. The only thing I don't like about nuclear is the long term waste storage problem. The waste from the nuclear plants that are online now is not stored properly and that waste can remain hazardous for thousands of years. The best treatment I have heard of for the waste is glassification. I don't know the details of the process, but somehow the waste is converted into a glass that cannot leak out of containers.
  • #138
Thanks for the info. When I've done some math I'll post more.
  • #139
Trash
This is the plan that I have been playing with for years. It is an all incompasing plan that fixes many problems all at once.
Trash is basically an under tapped resource. My plan would exploit it to it's fullest.
#1 (a) set up electrical genereation plants in every major metropolitin area that can support a trash burning plant. (b) Set up regional plants that can not support one on their own. (c) Smaller plants can be set up by smaller communities as well.
#2 (a) RECYCLE evry thing that is recyclable. This is almost everything. 7% of all trash is metal is is a very valubale commodity at this time. (b) there are small companies all over the US that are building small scale plants to turn plastic waste into recovered crude oil. Recycle plastic waste for this purpose. (c) The waste that is left over would be burned for electricity. (d) all recyclables would be sold at market value.
#3 (a) The work force would be made up of those that are less fortunate or the poor if you want to be realistic. (b)The jobs would be 1.25 times the minimum wage in your area. (c)The jobs would be to pull anything recyclable off the conveyor and sort it out. (d) other jobs would be child care persons, caffeteria workers, grounds keepers, janitors, and so on. After 4 hrs. of work you are entitled to a meal in the caffeteria. (e) Child care is provided on site for those that need it. (f) A medical clinic will be on site for those that work at least 15hrs. per week or for those in an emergency. (g) GED and community college clases would also be available to those completing a minimum of 32 hrs. per week. (h) This would effectively replace welfare.
#4 (a) This system could be used by anyone that needs assistance or just to make a few extra $. (b) Minimum work day would be 2 hrs. at a time. (c) Assisted people could taylor there work schedules to their needs. (d) State and federal offices could be located in the same plant for the ease of people working. (e) Using mass transit system to get there, would give you a .25 per hour bonus becasue of the savings it gives on the roads.
#5 (a) Empowerment classed could be taught, such as money management, parenting classes, drug and alcohol classes.
This will provide work fare instead of well fare. This will provide those that have a hard time finding jobs a place to work. This will recycle much of our trash that is wasted in landfills every year. This will allow people access to medical care. This will pull the main polutants (plastics and rubbers) out of the trash that is burnt making it a cleaner burn opperation. This will allow the reduction in land fills, the creation of power and the empowerment of those at the bottom to better them selves with a almost self sufficient system that eases the burdan on the tax payer. Even if this only supplimented the social system is would still do nothing but benifit overall.
I propose that tax breaks be given to companies that set these up or even use the government to set these up. I know the whole system seems a little Orwellian, but it is a system that would give people a choice about their situation and put the responsibility squarely on their own sholders while reducing polution, creating energy and creating a whole new class of productive citizens in our society who will now have the oppertunity to move up easier.
Likes supersheen
  • #140
I Have a simple thing we can do. Raise fuel Tax by 50 cents a gallon and use that solely for research and development of alternative energy sources. This way the biggest polluters become the biggest contributors for the solution.
