- #106
Dale
Mentor
- 35,337
- 13,562
OK, then using the Schwarzschild metric (in units where c=1, G=1, and M=1/2):Anamitra said:Regarding #103: I have sufficient difficulty in accepting what DaleSpam has to say. I have no hesitation in working out any homework problem he suggests. I have done this before.Nevertheless I would like to clarify my stand on this issue once more.
A freely falling lift is an inertial frame in the gravitational field of the earth.Now we may assign different velocities to it without spoiling the inertial nature of the frame. This may be accepted in a general way. We consider two transformations from the same metric leading to the Minkowski matrix[1 -1 -1 -1] in a local way.From special relativity we know that they must be moving with uniform speed with respect to each other. Now we divide our path from A to B into small intervals (A ,A1),(A1,A2)...(A[n-1],B)
In each interval we choose a frame with the same velocity V. The intervals being very small we choose for every interval V=V+delta_V approximately.So we have several coordinate systems which are not in relative motion.We may view them as rectangular coordinate systems in consideration of the Minkowski matrix[1 -1-1-1]Then we move our vector through these intervals.It remains constant since dA(mu)/dx(i)=0 for each interval.The vector remains unchanged at the end point B. For any other path we repeat the same manoeuvre starting with the same velocity at A.
In case there is some mistake in my method it has to be pointed out in a specific way. Of course I am ready to work out any practice problem suggested.No harm in doing that.
[tex]ds^{2} =
-\left(1 - \frac{1}{r} \right) dt^2 + \frac{dr^2}{\displaystyle{1-\frac{1}{r}}} + r^2 \left(d\theta^2 + \sin^2\theta \, d\phi^2\right)[/tex]
Start at [tex]t=0[/tex], [tex]r=2[/tex], [tex]\theta=45^{\circ}[/tex], [tex]\phi=0^{\circ}[/tex] and parallel transport an arbitrary vector to [tex]\theta=45^{\circ}[/tex], [tex]\phi=180^{\circ}[/tex] along:
a) the 45º colatitude line
b) the 0º and 180º longitude line
Work both cases using the standard parallel transport equation, and also try to work both using your "inertial frame" method.
