- #316
neopolitan
- 647
- 0
JesseM said:Sure, that's just the standard meaning of what coordinate transformation equations are meant to do (although a coordinate transformation can also transform the intervals between an arbitrary pair of events in one frame to the intervals between the same pair of events in another frame).
Yes, as I said I'm fine with defining events in abstract notation rather than numerical values.
Then I can't understand why you said this:
JesseM said:These equations wouldn't "speak" about any event in particular, they relate the coordinates of any arbitrary event in one frame to the coordinates of the same event in the other frame, but either way it is necessary that you have a specific physical event in mind.
I took that to be criticism, although I couldn't understand what alternative you were presenting.
By the way, you talk about coordinates and intervals. To avoid having to do that, can we agree that coordinates are intervals (just a specific one where one of the implied pair is the origin of the axis)? I have no problem with the idea of rearranging my axes to transform any interval into a single coordinate, or the reverse.
On the image, we could call the red dot a coordinate, but it is also an interval from the orange dot to the red dot. Between the red dot and the green dot is an interval, but if I redefined my axes so that (0,0) was the red dot, then the green dot would be a coordinate from the red dot. I don't see a huge difference between coordinate and interval for this very reason.
cheers,
neopolitan
