A Galvanometer of Coil Resistance 50 Ω Deflects Full Scale....
A galvanometer with a coil resistance of 50.0 Ω deflects full scale at 3.50 mA. To construct a voltmeter that deflects full scale for 35.0 V, the required series resistance is calculated using the formula Rv = (Vv/I) - Rg, resulting in Rv = 9,950 Ω. This indicates that the total resistance for the setup would be 10,000 Ω. Feedback from peers confirmed the correctness of the calculations and reasoning. The discussion emphasizes the importance of verifying calculations in physics problems.
AUAO1
A galvanometer of coil resistance 50.0 Ω deflects full scale for a current of 3.50 mA. What series resistance should be used with this galvanometer to construct a voltmeter which deflects full scale for 35.0 V
/Known Variables
[/B]
R1 + R2... + Rn = Rtotal
R = V/I
Vv = 35V; Rg = 50 Ω; I = 3.50 mA or 0.0035 A
Since a voltmeter occurs in a series, I have used the relevant equation above (Rv + Rg = Rtotal) where Rtotal = Vv/I (since current is constant). Replacing Rtotal with Vv/I gives Rv + Rg = Vv/I, so to find the resistance of the voltmeter, it would be Rv = (Vv/I) - Rg. Substituting the values in gives (35/0.0035) - 50 so Rv = 9,950 Ω (9.95 x 10^3 Ω). This means that Rtotal = 10,000 Ω (1.00 x 10^4 Ω).
Help and feedback is very much appreciated!
Hi AUAO1,
Welcome to Physics Forums!
Your reasoning and results look good.
They ask for the required resistance to put in series with the galvanometer, which you found to be 9950 Ω. The value of Rtotal wasn't necessary, but it's nice that you calculated it, too.
Likes AUAO1
Hello and thank you gneill!
Thank you for the quick response and feedback. It's always nice to be sure that I'm on the right track with these questions so your help is much appreciated!
Likes gneill
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
