- #106
maline
- 436
- 69
In your "inequality derivation" you assumed that the photon takes one path at the splitter. Bell's argument does not rely on any such assumption.
Isn't it already extremely weird to allow that a classical local hidden variable photon travels along several beams? I don't think that it is satisfying to explain away weirdness by basing the explanations on weird assumptions.maline said:In your "inequality derivation" you assumed that the photon takes one path at the splitter. Bell's argument does not rely on any such assumption.
Here is field type explanation of Bell inequality violation http://arxiv.org/abs/0906.1539. But it needs to exploit loophole to do that.A. Neumaier said:This is apparent from a (simpler) single-photon nonlocality experiments such as that discussed in my slides here (slides 46-59). The argument there doesn't extend to the setting under discussion here but shows that the assumptions of Bell are tied to an implicit particle assumption.
Classically, there are no photons, only an EM wave. Of course it spreads through space along all possible paths. Nevertheless, its polarization is a local variable, because it propagates at light speed.A. Neumaier said:Isn't it already extremely weird to allow that a classical local hidden variable photon travels along several beams?
No. There are no paths in a field context. And as any experimenter in classical optics knows, if you input a polarized electromagnetic wave focussed in a beam (in the paraxial approximation) into a beam splitter, the output will be a polarized electromagnetic wave focussed just along two beams. And its polarization is bilocal, not local. This is why one gets the quantum mechanical results and not the local hidden variable results.maline said:an EM wave. Of course it spreads through space along all possible paths
"Along all possible paths" was just a way of saying "as per Maxwell's equations". The point is that classically the wave must travel both ways, and there is nothing weird about that. "Photon" is purely a quantum- or rather a QFT- concept (and to me is indeed quite weird).A. Neumaier said:There are no paths in a field context
The word "local" in "local hidden variable" does not mean "localized to a particular region". It means "respecting the principle of locality"- the variable can be described as a function on spacetime (including delta functions) and values at particular points depend only on the past light cone of those points. Classical polarization of a wave definitely qualifies.A. Neumaier said:And its polarization is bilocal, not local. This is why one gets the quantum mechanical results and not the local hidden variable results
A. Neumaier said:This can become negative (uniformly random output independent of input), hence is not yet good. What about ##W=\max(0,\min(6\bar F-2\bar E-4,1))##? This would satisfy my requirements, and makes the specific case you described completely weird while leaving local hidden variable results not weird at all.
Local in local hidden variable theories cannot mean anything related to relativity theory - all of quantum mechanics is purely nonrelativistic!maline said:The word "local" in "local hidden variable" does not mean "localized to a particular region". It means "respecting the principle of locality"- the variable can be described as a function on spacetime (including delta functions) and values at particular points depend only on the past light cone of those points.
Anything with ##- \bar{E} + 3 \bar{F} \ge 2.5## has degree of weirdness 1 according to my amended formula.wle said:a) I know that quantum physics can attain ##- \bar{E} + 3 \bar{F} = 2.5##, but I don't have a proof that this is the maximum that is consistent with QM, and b) it's easy to define a set of hypothetical conditional probabilities (almost certainly not allowed by QM) that attain the algebraic limit [...] 4
edguy99 said:Thank you for the post. Can you add a sample calculation with 2 matrices to help some of us that may be a little confused by the terminology. Regards.
A. Neumaier said:So please point out where my arguments are faulty instead of arguing in a roundabout way that is too vague to spot the problems!
A. Neumaier said:Indeed, I have never seen a Bell-type argument where formal use was made of the the fact that values depend or do not depend on the past light cone.
I know that Bell (like earlier Einstein) used causality to motivate the experiment and to deduce nonlocality, but my emphasis was on ''formal use made of'' it. No formula involves anything relativistic - only the talk around it does. But the relevant physics is always in the formulas only, the accompanying talk is only interpretation. That's why multiple interpretations abound, while the formalism is universally agreed upon.wle said:in both, Minkowski diagrams depicting light cones are used as aides to the argument.
A. Neumaier said:I gave a local hidden variable argument of precisely the kind that was used by Bell and found a Bell-type inequality that was violated by the prediction of quantum mechanics. According to your criticism, there should be a fault in my formal reasoning since repeating the analysis using instead the Maxwell equations gives full agreement with the quantum predictions.
You didn't take Bell assumptions. If you modify Bell assumptions because you think they are weird does not change the fact that the assumptions used by you are not the ones used by Bell.A. Neumaier said:Isn't it already extremely weird to allow that a classical local hidden variable photon travels along several beams? I don't think that it is satisfying to explain away weirdness by basing the explanations on weird assumptions.
A. Neumaier said:... ruled out only under the assumption of a local hidden variable theory with signals moving independently along the rays to Alice and Bob. But this assumption is too strong to have implications when the signal is a field rather than particles.
Why isn't there a fourth part ##\gamma##, relevant to both Alice's and Bob's choice of detector setting? You make the assumption that this part is empty, but I cannot see a good reason for it. Thus ##F_A## and ##F_B## also depend on ##\gamma##, and Bell's argument breaks down.stevendaryl said:Let's split up the universe into three parts:
- The part λ relevant to the production of the twin-pair.
- The part α relevant to Alice's choice of her detector setting.
- The part β relevant to Bob's choice of his detector setting.
Yes, most of it. All of it comes from mixing in an inappropriate way different intuitions coming from incompatible formal settings.georgir said:you think the weirdness comes from thinking in terms of particles...
Why ##\gamma## can't be included into ##\lambda## ? What's so specific about ##\gamma## ?A. Neumaier said:Why isn't there a fourth part ##\gamma##, relevant to both Alice's and Bob's choice of detector setting? You make the assumption that this part is empty, but I cannot see a good reason for it. Thus ##F_A## and ##F_B## also depend on ##\gamma##, and Bell's argument breaks down.
All the Minkowski/relativistic principles you are applying are verified for macroscopic scales. A bunch of 'events' are happening in only a few microseconds, and robots are telling you they happened in a certain order - and gave certain measurement results. We then ascribe other events as being simultaneous with those. I would not stake a penny on that assumption being right unless I saw it with my own eyes. Which is impossible.ddd123 said:Neumaier, since back when instantaneous field were the norm we found out that spacetime is locally Minkowskian (as verified by atomic clocks on fast airplanes), so whatever the framework of the theory is, the Bell violations as proven by experimental loophole-free Bell tests (especially those avoiding the communication loophole) are still weird even if you abandon the particle idea.
That (unlike ##\lambda##, if I interpret its definition correctly) it is not determined by local information.zonde said:What's so specific about γ?
So you say that weirdness is a function of our knowledge about Nature? Then after a century of having found out that Nature is quantum we should have long adapted our conception of weirdness to find the clash between classical relativistic thinking and quantum mechanics natural (non-weird) in the same way that we no longer find the clash between instantaneous action and relativity weird.ddd123 said:since back when instantaneous field were the norm we found out that spacetime is locally Minkowskian
I don't see your point here. Bell's Theorem is a statement about which results cannot be reproduced by local, realist, counterfactual definite models. Such models, by definition, respect the light- speed boundary.A. Neumaier said:Local in local hidden variable theories cannot mean anything related to relativity theory - all of quantum mechanics is purely nonrelativistic!
If we allow FTL influences, then Bell's Theorem certainly does not apply! That's why we have models like Bohmian Mechanics or Continuous Reduction.A. Neumaier said:Indeed, I have never seen a Bell-type argument where formal use was made of the the fact that values depend or do not depend on the past light cone. The arguments never involve space or time at all, only simultaneity, which is intrinsically nonrelativistic!
The weirdness discussed here is not "deviation from intuition". It's more like "inability to form a picture of the fundamental reality". This is only relevant for models that are intended to be fundamentally accurate.A. Neumaier said:This is relevant - even if though classical theories are known to be approximations only - since weirdness is clearly primarily deviation from classical intuition. Hence if classical thinking in approximate classical theories such as celestial mechanics or hydromechnaics is already incompatible with no faster than light arguments, the weirdness is already due to this and not primarily to the quantum features.
I don't know of these difficulties. Please elaborate. Anyway, adding more problems does not a solution make!A. Neumaier said:2. In a classical relativistic setting, the notion of a 2-particle system is already ill-defined and fraught with conceptual difficulties. Only a single particle has a good relativistic description.
We are trying. We have tried for a century, and thus far our efforts have been met with failure. This thread is part of the ongoing attempt.A. Neumaier said:Then after a century of having found out that Nature is quantum we should have long adapted our conception of weirdness to find the clash between classical relativistic thinking and quantum mechanics natural (non-weird)
The culprit is the form of locality assumed in 1. to be able to conclude 2. This form of locality is not realized in Nature. However, Assumption 1 is a far stronger assumption than what follows from relativity = Lorentz invariance alone.maline said:Here is a short sketch of Bell's logic:
1.Given locality, and spacelike separation, Alice's detector settings and measurement result have no effect on Bob's measurement result.
2.Therefore, Bob's results depend only on the signal in Bob's region, and his settings.
6.Conclusion: one of the assumptions - locality, realism, or counterfactual definiteness- is not true of Nature.
To me it seems to articulate the ''inability to form a classical picture of the fundamental reality" - since the quantum picture is obviously an appropriate representation of fundamental reality. It allows us to predict and control a lot of stuff that 100 years ago were science fiction only.maline said:The weirdness discussed here is not "deviation from intuition". It's more like "inability to form a picture of the fundamental reality".
A. Neumaier said:So you say that weirdness is a function of our knowledge about Nature? Then after a century of having found out that Nature is quantum we should have long adapted our conception of weirdness to find the clash between classical relativistic thinking and quantum mechanics natural (non-weird) in the same way that we no longer find the clash between instantaneous action and relativity weird.
Yes, that's the very purpose of the threads.ddd123 said:The merit of these threads is that I've had my notion of weirdness clarified.
Yes, Bell locality is intended as a stronger assumption than "relativity holds". It is justified (for me) by:A. Neumaier said:However, Assumption 1 is a far stronger assumption than what follows from relativity = Lorentz invariance alone.
That brings up another point: as far as I know, no Lorentz invariant description has ever been given for QM including measurements. To me this is a hint that something important is missing from the fundamentals.A. Neumaier said:Modern relativity is the claim that Nature is ruled by Lorentz invariant laws, nothing else.
Ability to predict and control does not imply understanding. By a "picture of reality" I mean the ability to answer simple questions like "if an electron propagates through space as a wave, and then is detected at one point, what happens to the rest of the wave?"A. Neumaier said:the quantum picture is obviously an appropriate representation of fundamental reality. It allows us to predict and control a lot of stuff
This was not part of a solution - which is partly indicated in this post - but part of my argument that weirdness is not in the quantum part but in the particle part.maline said:I don't know of these difficulties. Please elaborate. Anyway, adding more problems does not a solution make!
It would be enough to have a language that forbids asking questions such as this because they are meaningless.maline said:By a "picture of reality" I mean the ability to answer simple questions like "if an electron propagates through space as a wave, and then is detected at one point, what happens to the rest of the wave?"
A. Neumaier said:I know that Bell (like earlier Einstein) used causality to motivate the experiment and to deduce nonlocality, but my emphasis was on ''formal use made of'' it. No formula involves anything relativistic - only the talk around it does.
From my point of view, nothing more mysterious happens in Bell's experiment [...]
[...] since exactly the same algebra is used [...]
stevendaryl said:The point is that Alice's and Bob's choice of detector settings can be made at a spacelike separation. There is no reason to assume that their choices have anything in common. For example, let's suppose that each of them is carrying a little chunk of uranium, and they base their decision on which setting to choose on the number of decays (indicated by Geiger counter clicks) in a certain time interval. Then aren't those two choices completely independent? (At least, according to mainstream QM)
