- #351
kith
- 535
I'd like to point out two subtleties which haven't been mentioned in this thread yet. I think both might be relevant to the discussion with vanHees71.PeterDonis said:Therefore, a superposition of spin eigenstates ##\vert \psi \rangle = a \vert z+ \rangle + b \vert z- \rangle##, where ##\vert a \vert^2 + \vert b \vert^2 = 1##, will induce evolution as follows:
\vert \psi \rangle \vert R \rangle \rightarrow a \vert z+ \rangle \vert U \rangle + b \vert z- \rangle \vert D \rangle
This state does not describe "a single outcome"; it describes a superposition of "outcomes". But this state is what unitary evolution predicts. So if in fact the final state is not the above, but either
or
with probabilities ##\vert a \vert^2## and ##\vert b \vert^2## respectively, then some other process besides unitary evolution must be involved, and this other process is what is referred to by the term "collapse".
First, proponents of the ensemble interpretation might say that the final state really is the full final state which involves a superposition of macroscopically distinct apparatus states (Ballentine does this in his textbook, see section 9.3, 1st edition). This is possible because in the ensemble interpretation, states do not refer to single systems.
Second, let's look at a very similar situation which prepares a beam of particles in state [itex]|z+ \rangle[/itex]. Suppose that we modify your device such that particles which would hit the "UP"-part of the detector are transmitted and particles which would hit the "DOWN"-part are reflected back, becoming trapped in the device. The final state then is $$a|z+, \text{transmitted} \rangle \otimes |\psi_\text{Device} \rangle \,\,+\,\,\, b|z-, \text{trapped}\rangle \otimes|\phi_\text{Device} \rangle $$ If we use [itex]|z+ \rangle[/itex] as the state for further measurements, it looks like a textbook example of collapse. What actually happens is that we make the choice to use only the first part of the final state because we know that the overlap of the second term wrt to the eigenstates of all subsequent observables is zero. So in this case, "collapse" is simply the redefinition of what the system of interest is.
