- #106
- 14,239
- 6,717
Except that the appearance of a rabbit is what the whole trick is about.vanhees71 said:No rabbit in sight
So how would you qualify my attempted explanation of rabbit-from-the-hat in the entry 5)? Is it philosophy? Don't you do something similar when you see a performance by a magician?vanhees71 said:Where is a trick in phenomena (no matter whether quantum or not)? It's what we observe nature does, and there's nothing else we can do. What do you want when you asking for knowledge how Nature does it? You'll never get an answer from the natural sciences, and philosophy leaves you most probably unsatisfied since it's not explaining anything either.
How do you do that without mathematics?Demystifier said:without mathematics, just by visualizing localized wave packets and particle trajectories within them.
Arnold already criticised some points in his post #16 and you didn't respond to it.Demystifier said:Which does not mean that one does not need to criticize the specific gaps in order to criticize the final conclusion of the argument.
That's what physicists try to do, but I don't think that anything about Bohmian mechanics can be considered rational. It's so irrational that most physicists even consider something as stupid as "shut up and calculate" to be more rational than BM. Arnold's list in post #84 can be continued almost indefinitely. In additional to what is absurd about BM, I also consider it highly irrational to expect naive 17th century ideas about physics to be the final word.Demystifier said:5) Try to devise a rational mechanism which could explain it.
I meant without equations. I can visualize a wave packet and a trajectory without having an equation in my mind.A. Neumaier said:How do you do that without mathematics?
What is the most rational interpretation of QM in your opinion?rubi said:That's what physicists try to do, but I don't think that anything about Bohmian mechanics can be considered rational. It's so irrational that most physicists even consider something as stupid as "shut up and calculate" to be more rational than BM.
Demystifier said:Does your attempted explanation involve some hidden variables, like those in 5) above?
Mentz114 said:Does the rabbit have a definite position before it is pulled out of the hat ? Or is that interpretation dependent ?
Why not? I think you can.Spinnor said:I can not, right?
I'd say that's the most rational "explanation" of the phenomenon, and I'd consider it the most convincing one too. I, however, don't see in which this sense is an analogue to Bohmian mechanics. In your rabbit example you can check your assumptions and figure it out (provided the magician allows you to investigate his setup), while Bohmian mechanics claims unobservable trajectories and doesn't offer anything more than standard QT. I don't see, why I should evaluate the trajectories, if I can't check the result against experiment (except for the fun in the sense of a mathematical puzzle I solve for my pleasure).Demystifier said:So how would you qualify my attempted explanation of rabbit-from-the-hat in the entry 5)? Is it philosophy? Don't you do something similar when you see a performance by a magician?
You have a point, but what if, for some reason, magician never allows you to investigate his setup? Would that change anything?vanhees71 said:I'd say that's the most rational "explanation" of the phenomenon, and I'd consider it the most convincing one too. I, however, don't see in which this sense is an analogue to Bohmian mechanics. In your rabbit example you can check your assumptions and figure it out (provided the magician allows you to investigate his setup), while Bohmian mechanics claims unobservable trajectories and doesn't offer anything more than standard QT. I don't see, why I should evaluate the trajectories, if I can't check the result against experiment (except for the fun in the sense of a mathematical puzzle I solve for my pleasure).
Demystifier said:Why not? I think you can.
No. It ruled out local hidden variables. Non-local hidden variables, such as those in Bohmian interpretation, are not ruled out.Spinnor said:I though Bell's theorem ruled out Hidden Variables?
Nature does not allow us to observe her hidden variables, which is precisely why they are called hidden.vanhees71 said:Nature seems not to be that malicious since obviously she allows us to observe her.
But even then, you would use pure thinking to try to figure out how the magician does it, wouldn't you?vanhees71 said:Well, then natural science must capitulate, i.e., its methods cannot be applied to the magician's trick, because he doesn't allow to apply them.
vanhees71 said:Sure, but it will stay speculative, if you cannot verify your thinking by observations. The same holds for Bohm's trajectories. They are ficticious, because they cannot be observed. I still don't understand what merit Bohm's additions may have for the understanding of QT.
Well, you confirmed that you would use pure thinking to try to figure out how the magician does it, even though it would stay speculative. What's the merit of that? Whatever the merit of speculation about magician tricks might be (and there must be some, because you confirmed you would do it), the merit of the Bohmian interpretation is completely analogous.vanhees71 said:Sure, but it will stay speculative, if you cannot verify your thinking by observations. The same holds for Bohm's trajectories. They are ficticious, because they cannot be observed. I still don't understand what merit Bohm's additions may have for the understanding of QT.
How can Bohmian mechanics remove the Heisenberg cut (whatever you mean by that; I've neither found in LL nor Weinbergs QM textbook(s)) if it doesn't provide anything different from standard QM than the introduction of unobservable new elements?atyy said:The aim of Bohmian mechanics is to remove the Heisenberg cut, which is needed in the orthodox interpretation eg. used by Landau and Lifshitz and Weinberg in their QM textbooks.
I don't know, what's the merit of understanding a magicians trick. Perhaps, it's not even useful to find if you like to be rather entertained by the show? My point is that there's no additiona merit in Bohmian interpretation compared to the physical core of QT. It's maybe nice for some people who like to stick to classical pictures like trajectories of particles although they are contradicting observations and are thus in Bohmian mechanics not to be taken as observable. But that's rather introducing a "magician's trick" rather then undertanding what's behind it. For me the problem is, why I should think about QM as a "magician's trick" rather than just the so far best description of nature we have today and then add a "magician's trick" to figure out "what's behind it" (QM). In this sense it's somehow self-contradictory in its aims.Demystifier said:Well, you confirmed that you would use pure thinking to try to figure out how the magician does it, even though it would stay speculative. What's the merit of that? Whatever the merit of speculation about magician tricks might be (and there must be some, because you confirmed you would do it), the merit of the Bohmian interpretation is completely analogous.
So if you want me to tell you what's the merit of Bohmian interpretation, first you must tell me what's the merit of speculations about magician tricks.
Or alternatively, if you insist that merit must be practical, then see the link in post #87.
vanhees71 said:How can Bohmian mechanics remove the Heisenberg cut (whatever you mean by that; I've neither found in LL nor Weinbergs QM textbook(s)) if it doesn't provide anything different from standard QM than the introduction of unobservable new elements?
Then why do you try to understand it? Seriously, if you really want to understand why some people care about Bohmian mechanics (which doesn't mean that you should care too), then you need to do some self-psychoanalysis and answer the question why do you care about trying to understand how the magician trick works. Only when you answer that question about yourself you will have chance to put yourself into the mind of a Bohmian.vanhees71 said:I don't know, what's the merit of understanding a magicians trick. Perhaps, it's not even useful to find if you like to be rather entertained by the show?
How can you hope to understand how Bohmian mechanics removes the Heisenberg cut if you don't even know what Heisenberg cut is?vanhees71 said:How can Bohmian mechanics remove the Heisenberg cut (whatever you mean by that; I've neither found in LL nor Weinbergs QM textbook(s)) if it doesn't provide anything different from standard QM than the introduction of unobservable new elements?
Demystifier said:The question for everybody: What do you do when you see a magician trick?
vanhees71 said:I know what the Heisenberg cut is, but I've no clue, where Weinberg and Landau-Lifshitz mentioned it. If you mean the classical behavior of macroscopic systems, including measurement devices, of course for me there is no such cut. Classical behavior of macroscopic systems is for me an emergent phenomenon due to the very coarse-grained observations I do on macroscopic objects. It's all "averaging" over the microscopic details, and thus engineers and experimental physicists can use the classical description to develop measurements devices, particle accelerators, rockets to fly to the moon, and so on.
I wonder why all this interpretational debates seem to ignore the fact that we have relativistic QFT, and that it has been checked to make accurate predicitions to many decimal places. So any interpretation one may want to give to quantum theory must agree with the postulates that go into renormalized interacting 4-dimensional QFT, one of them is locality, so any interpretation that uses non-local hidden variables is not a plausible interpretation in the context of assuming the success of QFT as our most accurate quantum theory.Demystifier said:No. It ruled out local hidden variables. Non-local hidden variables, such as those in Bohmian interpretation, are not ruled out.
RockyMarciano said:one of them is locality, so any interpretation that uses non-local hidden variables is not a plausible interpretation
Well, if you decide that non-local is compatible with local there seems to be not much more room for discussion. I would say that if non-local hidden variables are made compatible with relativistic locality they are actually local hidden variables.PeterDonis said:This is not correct. The QFT version of "locality" is that operators at spacelike separated events must commute--in other words, the results of measurements at spacelike separated events cannot depend on the order in which the measurements are made. That is compatible with non-local hidden variables.
RockyMarciano said:I wonder why all this interpretational debates seem to ignore the fact that we have relativistic QFT, and that it has been checked to make accurate predicitions to many decimal places.
But it adds something to the locality problem discernment, according to Bell's theorem you still have the option when disposing of local realism to choose between discarding realism(classical determinism) or discarding locality, and so the Bohmian interpretation would choose to discard locality and keep classical determinism. But the QFT that produces high precision predictions is a local theory and leaves no choice but giving up classical determinism.stevendaryl said:Well, as I understand it, the locality problems with quantum field theory are not really any different than for quantum mechanics. Roughly speaking, we have two parts to quantum mechanics:
QFT modifies #1, but it doesn't change #2, which is where the interpretation difficulties arise.
- Calculate amplitudes for various outcomes using Schrodinger's equation.
- Use the amplitudes to compute probabilities for measurement outcomes.
