Assighment question based on Tension
  • Thread starter Thread starter Krist
    Tension
The discussion revolves around a physics problem involving a waterskier being pulled by a rope with a tension of 240 Newtons. The net force acting on the skier is determined to be 160 Newtons, which is the force required to overcome resistance and achieve acceleration. The correct acceleration of the skier, when considering only the tension as the horizontal force, is calculated to be 3 m/s². Participants clarify that the net force should not be summed with the tension, as the tension itself is not the net force but rather one of the forces acting on the skier. Overall, the conversation highlights confusion around the application of Newton's laws and the relationship between tension and net force.
Krist
1. A waterskier of mass 80kg, starting from rest, is pulled along in a northerly direction by a horizontal rope with a constant tension of 240 Newtons. After 6 seconds he has reached a speed of 12m/s.
1. What is the net force on the skier?
2. If the tension in the rope were the only horizontal force acting on the skier, what would his accelleration be?
3. What is the sum of the resistance forces on the skier.
2. Any of Newtons laws + constant acceleration
3. Ok guys, what I've managed to gather is the acceleration is 2m/s/s, initial velocity=0 and obviosly tenstion = 240N
To get the mass moving without resistance would require a force of 160N.
F=ma
F= 80 *2
F=160N
Now if i add them together will i get net force? NetF= 160 + 240 = 400N?
I'm not sure on that one, i am not clear about what to do with the tension measurement...does it affect both sides? Does it mean that the skier is only getting pulled with half the amount of Force?
For Q2.
F = ma
240 = 80 * a
a = 3m/s/s
^ Is that right?
Finally for Q3, i can only guess taking 160 away from 240...bringing resistance to 80N.
I'm really not sure on any of these and our teacher kind of flew threw tension section.
Hi Krist,
A couple of your statements don't seem right to me.
That's true; but the point is even with resistance it still requires net force of 160N. In terms of the net force in the horizontal direction you have:
<br /> F_{\mbox{net},x} = m a_x<br />
F=ma
F= 80 *2
F=160N
The 160N is the net force. Writing the equation in terms of the individual forces instead of the net force gives, for the horizontal direction:
<br /> \begin{align}<br /> \sum F_x &amp;= m a_x\nonumber\\<br /> T_x + R_x &amp;= m a_x\nonumber<br /> \end{align}<br />
which gives the answer you found in question 3.
For Q2.
F = ma
240 = 80 * a
a = 3m/s/s
^ Is that right?
